Rear A6-4B Window: Automatic Open Issue?
quattrotdi
Post23-03-2006, 20:50    Subject: Rear A6-4B Window: Automatic Open Issue? Quote
hello,
I need your help again.
A6 Avant Quattro, manufactured in November 2002, TDI engine with 180 horsepower.
Does the left rear window sometimes open during driving and then cannot be closed immediately using the window switch?
We have already deactivated the comfort control!
Once, while driving the station wagon, the display panel popped open.
Hatchback displayed!
I would be grateful if you could tell me where the error is most likely located.
'or how to find the error?'
I've already heard about a lot of things, from door locks to window motor and window switch replacements.
oser rear door lock.
But maybe one of you has encountered this exact issue before?
Thank you for any help.
quattrotdi
Translated on 07-08-2026, 1:37.
siliconsensing
Post28-03-2006, 9:14    Subject: Rear A6-4B Window: Automatic Open Issue? Quote
I also once experienced the self-opening tailgate on my A4 B5; it was quite impressive.
The microswitches in the gate opener were oxidizing inside the gate mechanism, causing them to short circuit. This resulted in the gate repeatedly opening unexpectedly – it was incredibly frustrating.
That would never have happened back then.
The problem with the windows is probably related to the comfort electronics system; there are a lot of microswitches in there. If it's not due to that, things will get more complicated!
But the signal to open must come from somewhere – so you'll have to check the cables, disconnect them, and test things... good luck with that!
Have you tried using VAGCOM yet?
Translated on 07-08-2026, 1:40.
No new posts Do windows open on their own? General Tips
No new posts Doku Polo MJ 2002, windows open automatically Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Quietschen Vorderachse links (Golf4) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8PA rear left brake dragging Transmission, Chassis, Body & Interior
No new posts Back door lock, Touran, left side, defective. Transmission, Chassis, Body & Interior
No new posts Audi A4 B8, rear left brake warm Transmission, Chassis, Body & Interior
No new posts Audi A4: Rear Left Door Won't Open? Transmission, Chassis, Body & Interior
