A3 1.9 TDIi braucht plötzlich dramatisch mehr Sprit! | Posts 16+
Go to page: Previous  1, 2
Herr Antje
Post03-05-2006, 6:28    Subject: Quote
96kwtdi wrote:
What do you mean by "sex marathon"? I don't quite understand.
As I understand it, he's talking about everything you could potentially try until you resolve the problem.
Starter, battery, VP37 engine, fuel injectors, and then there's the issue with the compression.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 11-10-2026, 6:53.
Post03-05-2006, 17:45    Subject: Quote
Starter, battery, VP37, fuel injectors, and then there's the issue with the compression.
gerbi
Post03-05-2006, 21:59    Subject: Quote
It's not a problem to change it via a chip modification, but I haven't had any cars with a 'start problem' yet.
However, it works perfectly well with plant-based diesel fuels.
Is there a chance to achieve this without reprogramming the chip, perhaps through adjustment channels? Or is it unavoidable? If so, are there any known offsets in the memory where this can be influenced?
Translated on 11-10-2026, 6:54.
Post04-05-2006, 8:44    Subject: Quote
Hi Gerbi,
gerbi wrote:
Rainer K. wrote:
It's not a problem to change it via a chip modification, but I haven't had any cars with a "start problem" yet.
not that I know. Otherwise, I wouldn't need to tinker with the chip, but I would just briefly connect a VAG-COM icon_lol.gif.
The 'offsets,' as you call them, are, of course, familiar to me; otherwise, I wouldn't be offering this service. Fortunately, they are different in almost every engine control unit/software version icon_cool.gif.
Translated on 11-10-2026, 6:56.
cksIT
Post04-05-2006, 13:40    Subject: Quote
Things like the battery can be easily tested. Just try bridging it and starting the other car. If it starts better, you've found your problem.
Translated on 11-10-2026, 6:57.
No new posts How to drive fuel-efficiently. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN suddenly no longer starts. Diesel Engine Technology
No new posts Control Unit 46: Suddenly Unreachable? On-Board Diagnostics (OBD)
No new posts 1.9 TDI suddenly lost power and has an unstable idle Diesel Engine Technology
No new posts VAG-COM 409: Troubleshooting & Fixes On-Board Diagnostics (OBD)
