Bei 160 km/h laut Tacho plötzlich ein Ruck und keine... | Posts 16+
Go to page: Previous  1, 2
DocSnydor
Post22-10-2003, 14:40    Subject: Quote
@ Warlord
@dieselmartin
I already exchanged mine too. The new one makes the same amount of noise (I would describe it more as rattling) as the old one. Sometimes it does it even when the car is stationary, sometimes it doesn't...
Translated on 04-10-2026, 23:00.
WarLord
Post22-10-2003, 17:32    Subject: Quote
@Dirk-16
So, should I just apply lubricant to the area where the shaft goes into the loader? I should really push the lubricant in there, right? About how long would that last?
Best regards, WarLord.
Translated on 04-10-2026, 23:01.
Post23-10-2003, 9:02    Subject: Quote
@ Doc and Dirk
I definitely had the turbocharger wastegate valve in my hand!
http://people.freenet.de/golf-schrauber/Magnetventil.jpg
It rattles even when I just turn the ignition on (i.e., the engine is not running!!!).
I've already had LEDs on it, and they're powered on while the vehicle is stationary (it's weird, but that's how it is).
The AGR valve is silent.
Currently, I have it wrapped in foam and secured with duct tape, but icon_cry.gif it hasn't helped.
Three different Volkswagen dealerships have three different opinions: one says "it's normal," another says "it's slowly breaking down," and the third says "it's broken."
And electrical parts are excluded from returns, so I can't try to see if a new one is quieter... (I read that in another forum, where someone said a new one [for an Audi] was silent).
Do yours also rattle when stationary?
Translated on 04-10-2026, 23:02.
DocSnydor
Post23-10-2003, 10:55    Subject: Quote
Das macht meins nicht. Never!
same here.
What's the point? So you don't hear the noise anymore?
Three different Volkswagen dealerships have three different opinions: one says 'it's normal,' another says 'it's going to break down soon,' and the third says 'it's broken.'
Yes, I've had that experience too. The opinions about it vary widely... icon_rolleyes.gif
Yes, but I already posted that. As I said, it's not always like that...
I'm just going with what works for me, and I don't really care as long as it's functional.
Translated on 04-10-2026, 23:04.
WarLord
Post23-10-2003, 14:13    Subject: Quote
@dieselmartin
Mine rattles too, even when the engine is off (meaning only the ignition is on).
Translated on 04-10-2026, 23:05.
Enzo F
Karma: +1 / -1   Thank you, like it!
Post15-05-2006, 12:03    Subject: Quote
Aloha everyone!
Based on my experience, I can say that the wastegate valve is still working as long as it rattles. HOWEVER: I've read (here) that rattling even when the ignition is on can indicate a defect, and in that case, replacing it helped. Unfortunately, I don't have a link to that information; I'm currently searching a lot about engine misfires because I'm trying to help my uncle with his TDI misfire (Audi B4 1Z, year 1994). So, I've only read about it...
Based on my reading experience, I'd like to point out that the mass airflow sensor (MAF) could also have a loose connection, right? The errors and symptoms seem to indicate a problem with the MAF sensor, or have I misunderstood something?
Torsten.
VW Golf III Variant TDI 1Z 66kW EZ 5/96
269.000km
Translated on 04-10-2026, 23:06.
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 TDI: Speedometer Error - Only 215 km/h? Diesel Engine Technology
No new posts 1.9 TDI suddenly lost power and has an unstable idle Diesel Engine Technology
No new posts VW Golf 4: Replace Analog Speedometer with FIS Display Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Engine Jerk with DPF: Causes & Solutions Diesel Engine Technology
