Adjust VTG Without VAG Tool
Tobias
Post26-11-2002, 9:10    Subject: Adjust VTG Without VAG Tool Quote
Hello everyone,
I'd be interested to know if you have any tips on how to properly adjust the VTG (Variable Turbine Geometry) without using a VAG tool or a boost pressure gauge.
I came up with something, but I'm not sure if it will work.
2nd gear, going uphill (gradient 10-18%), engine speed approximately 1200 rpm, then full throttle, and noticeable acceleration from around 1800 rpm.
Increasing acceleration before 1800 rpm -->> excessively aggressive VTG (Variable Turbine Geometry).
Increasing acceleration after 1800 rpm indicates a VTG (Variable Turbine Geometry) that is open for too long.
What do you think about it?
Greetings from Lake Constance.
P.S.: We have an ASV with an *** chip.
Translated on 15-09-2026, 9:08.
Post26-11-2002, 10:33    Subject: VTG Adjustment: How to Without VAG Tool Quote
Tobias wrote:
Do you have any tips on how to properly adjust the VTG without a VAG tool or a boost pressure gauge?
Unfortunately, at that point, it's no longer a setting, but pure guesswork.
In my opinion, it's not suitable for assessing the settling behavior.
Translated on 15-09-2026, 9:10.
Tobias
Post26-11-2002, 10:46    Subject: Adjust VTG Without VAG Tool Quote
Hello Rainer,
Okay, okay... you're right.
How do I properly configure the VTG using the VAG Tool?
Post26-11-2002, 10:52    Subject: Adjust VTG Without VAG Tool Quote
/viewtopic.php?t=501&highlight=vtg+einstellen
Translated on 15-09-2026, 9:11.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diagnostic Tool Göttingen: Find the Best! On-Board Diagnostics (OBD)
No new posts Torque Measurement (TDIs) with KPower Tool On-Board Diagnostics (OBD)
No new posts Ford Focus TDI Diagnostic Tool (2000) On-Board Diagnostics (OBD)
No new posts ESP Adjustment: 1.6 TDI Guide Diesel Engine Technology
