Fuel Injectors Audi A6 2.5 TDI 140 HP AEL
stefan123
Post07-06-2006, 20:13    Subject: Fuel Injectors Audi A6 2.5 TDI 140 HP AEL Quote
Can anyone tell me where I can find a used set of fuel injectors at a reasonable price?
My A6 has now reached 235,000 km, but it's starting to make concerning noises after I've driven about 1 km. After another 10 km or so, this knocking sound almost disappears, unless the engine is idling for a while, for example, at a traffic light. Can anyone help me with this?
Translated on 09-09-2026, 0:40.
Nebelwerfer_TDI
Post08-06-2006, 7:59    Subject: Fuel Injectors Audi A6 2.5 TDI 140 HP AEL Quote
Wrong forum, boosting it up.
Forget about using used nozzles; if you're going to replace them, use new ones. Rainer can help you with that if you don't want to disassemble the nozzle holders yourself.
Are you sure it's the injectors? It could also be the timing chain, which is occasionally delivering the signal late, causing premature injection. It's best to replace the timing chain. It might cost a bit more, but it's definitely worth it. You'll be amazed at how little smoke it produces afterward, and the fuel consumption should also decrease.
Translated on 09-09-2026, 0:41.
Post08-06-2006, 8:45    Subject: Fuel Injectors Audi A6 2.5 TDI 140 HP AEL Quote
Yep, in this case, first check the start of the injection process while the vehicle is in motion.
Translated on 09-09-2026, 0:42.
olli
Karma: +46 / -0   Thank you, like it!
Post13-06-2006, 23:05    Subject: Fuel Injectors Audi A6 2.5 TDI 140 HP AEL Quote
The concerning noises are usually caused by a faulty vacuum pump or plunger in the 5ender.
Press the brake pedal a few times in a row when you hear that noise; it might go away.
Best regards from Berlin.
Olli.
A6 CANA/JME /
Ex-A6 AEL
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts VW/Audi V6 TDI AKE: Starting Problems Diesel Engine Technology
No new posts VW 1.9 TDI Oil Leak: ARL Engine - Fix It! Diesel Engine Technology
No new posts Audi A4 B5 Automatic Transmission Problems? Transmission, Chassis, Body & Interior
No new posts TDI Injectors: AFN to 1Z Conversion Guide Diesel Engine Technology
