Error 65535: External Pressure & Emergency Mode
Jones1978
Post14-06-2006, 20:00    Subject: Error 65535: External Pressure & Emergency Mode Quote
Hi everyone,
My Passat also has a slight power issue, and it occasionally switches into limp mode.
"While logging data, I noticed the following: When the engine speed exceeds 3000 RPM, the boost pressure drops suddenly to approximately 690 mbar (from around 1130 mbar previously), and I receive the error code 65535, indicating a defective engine control unit. Subsequently, during the next acceleration, I get the error code 0575, which indicates a regulated intake manifold pressure issue, leading to the control unit being locked."
The outside pressure remains at this value as long as the error persists, which can only be cleared when the engine is "cold" (below 60°).
MKB: AHU
LLM and N75 sensors replaced - Hoses checked/replaced, air filter inspected/replaced.
"The turbocharger is easily accessible; the EGR valve is also easily accessible, the catalytic converter is clear, and the turbocharger spins freely."
Jones.
Translated on 22-10-2026, 22:58.
Rudi
Post14-06-2006, 20:39    Subject: Error 65535: External Pressure & Emergency Mode Quote
I'm familiar with that error (unfortunately).
The cause is the height sensor in the engine control unit. Unfortunately, the only solution is to replace it.
Best regards, Rudi.
Translated on 22-10-2026, 23:00.
Post14-06-2006, 21:05    Subject: Error 65535: External Pressure & Emergency Mode Quote
Error 65535, engine control unit (ECU) defective.
Yep, that's unfortunately correct. The pressure sensor is located in the control unit, and it's probably easier to get a working control unit from a junkyard than to find the sensor itself.
Translated on 22-10-2026, 23:01.
Dj Ninja
Karma: +1 / -1   Thank you, like it!
Post15-06-2006, 13:03    Subject: Error 65535: External Pressure & Emergency Mode Quote
I would like the old control unit for testing purposes if you are getting a new one (K-line protocol to the microcontroller), so please don't just throw it away! icon_biggrin.gif
Jones1978
Post16-06-2006, 9:17    Subject: Error 65535: External Pressure & Emergency Mode Quote
Thank you for the quick (though not very pleasant) responses.
I will icon_biggrin.gif contact him shortly to find out when he is available.
Dj Ninja wrote:
"No way - I won't do that, even though I might be tempted - maybe it still needs to be kept around as a source of spare parts."
lg jones
Translated on 22-10-2026, 23:02.
Rudi
Post16-06-2006, 9:44    Subject: Error 65535: External Pressure & Emergency Mode Quote
Thank you for the quick (although not very pleasant) responses.
I'm going to contact my icon_biggrin.gif right away to see when he's available...
Original spare part icon_eek.gif?
Which car are we talking about? The prices range from around 800 to 1400 EUR.
Rudi
Translated on 22-10-2026, 23:03.
Jones1978
Post16-06-2006, 9:51    Subject: Error 65535: External Pressure & Emergency Mode Quote
My icon_biggrin.gif is a friend of mine who has his own workshop, so let's see what he might have available.
It's a Passat wagon.
Translated on 22-10-2026, 23:04.
Post16-06-2006, 10:36    Subject: Pressure Error 65535: Emergency Mode Activated Quote
Jones1978 wrote:
When the engine exceeds 3000 RPM, the outside pressure suddenly drops to approximately 690 mbar (previously around 1130), and I receive the error code 65535, indicating a defective engine control unit.
Rudi wrote:
I am familiar with that error (unfortunately).
The cause is the altitude sensor in the engine control unit. Unfortunately, the only solution is a new engine control unit
Hi Rudi,
That's a rather peculiar error pattern if it were only due to the altitude sensor.
"1130 mb is far too much external pressure, because the usual maximum (extreme high pressure at sea level) is probably around 1050 mbar, in my opinion."
690 mbar already corresponds to considerable altitudes (approximately 2500 - 3000 meters).
How can the altitude controller "sense" that the 3000 rpm threshold has been exceeded, and then switch from "stupidity" level 1 to "stupidity" level 2 icon_eek.gif icon_question.gif?
Translated on 22-10-2026, 23:05.
Rudi
Post16-06-2006, 12:10    Subject: Error 65535: External Pressure & Emergency Mode Quote
It's a Passat Variant. The Passat has been produced since 1974. The TDI version has been available since the early 1990s new_tomato.gif.
@Ulf
The altitude sensor is defective and providing nonsensical readings. It starts malfunctioning at speed x.
It resonates and ultimately makes no sense.
However, there's another possible explanation: it could be a very old 1Z.
In that case, the height sensor would have had to be located outside the MSTG, just like in the G3.
Then there's also the possibility of a resonance-induced intermittent connection in the wiring.
Question.
'lg' is an abbreviation for 'liebe Grüße,' which means 'best regards' or 'love.' It is often used in emails and letters to express affection or friendship.
Here is an example of how 'lg' might be used in a sentence:
'I hope you are doing well. lg, [Your Name]'
In this example, 'lg' is used to express affection and friendship. It is a way of saying 'I care about you' or 'I am thinking of you.'
Translated on 22-10-2026, 23:08.
Jones1978
Post16-06-2006, 12:38    Subject: Error 65535: External Pressure & Emergency Mode Quote
Rudi wrote:
It's a Passat variant
- Sorry, the signature wasn't up-to-date yet.
MKB AHU, but only since the end of 96-00 - as stated above icon_wink.gif.
I'll adjust the measurement curves later today, after work.
Sure, here's the translation:
"Best regards," or "Sincerely,".
Jones.
Passat 3b 1.9 TDI 08/97; 66kw MKB AHU
it's not a bug - it's a feature
Translated on 22-10-2026, 23:10.
bastion
Karma: +6 / -1   Thank you, like it!
Post16-06-2006, 13:09    Subject: Error 65535: External Pressure & Emergency Mode Quote
Can't the height sensor simply be replaced with an external one with a little DIY work, or could the engine control unit (ECU) be mounted in a way that dampens vibrations if the problem is due to resonance?
A4 Avant 08/01 AWX 05/08-
Translated on 22-10-2026, 23:11.
Rudi
Post16-06-2006, 13:31    Subject: Error 65535: External Pressure & Emergency Mode Quote
icon_redface.gif ... My mistake.
Then it's definitely an EDC15 (new, approximately 1050 EUR) with an integrated sensor.
I would try to get a used STG (steering control unit) from eDings and replace the sensor.
@Bastion:
Externally, you can ignore it; damping probably won't help (anymore) since the baseline noise levels are already...
are wrong.
Rudi
bastion
Post16-06-2006, 13:34    Subject: Error 65535: External Pressure & Emergency Mode Quote
Okay, then let's at least try to dampen the sound. If it works, we can postpone buying the silencer for now.
Translated on 22-10-2026, 23:12.
Dj Ninja
Post16-06-2006, 16:25    Subject: Error 65535: External Pressure & Emergency Mode Quote
The 1Z/AHU control units are not very expensive on Schrottbay.
Translated on 22-10-2026, 23:13.
Jones1978
Post16-06-2006, 19:49    Subject: Error 65535: External Pressure & Emergency Mode Quote
Okay,
Today, I conducted a new measurement. The altitude sensor gave the expected nonsensical readings. However, this stupid thing refused to go into emergency mode. It seems like it doesn't care.
The boost pressure curve actually looks quite good.
You can find the measurement file and the screenshots of the situations here:
http://jones1978.jo.funpic.de/vag-com/
At least now I have something to keep me busy this weekend.
*g
jones
Devilseye503
Post19-06-2006, 23:19    Subject: Error 65535: External Pressure & Emergency Mode Quote
icon_eek.gif Is this sensor really such a huge problem? I just can't imagine not getting it. icon_question.gif icon_idea.gif
@jones1978 - Could you record a video when you start opening the MSTG?
Translated on 22-10-2026, 23:14.
No new posts Airbag Error 65535: A3 8L Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag Error 65535: A3 8L Fix (up to 8LYA078299) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 TDI: Airbag Error 65535 - Troubleshooting On-Board Diagnostics (OBD)
No new posts P046C Error: Troubleshooting & Fixes On-Board Diagnostics (OBD)
No new posts Audi A8: Fuel Injection Error - Limp Mode? On-Board Diagnostics (OBD)
No new posts Golf AJM Error 17958: Troubleshooting & Photos On-Board Diagnostics (OBD)
