Hello everyone,
I've used VAG-COM and discovered that the throttle pedal on my Passat 3B is set to a very 'late' position, meaning that 100% throttle is only reached when the pedal touches the floor. If I release the pedal by just 1 mm, the value jumps to 98.8%. I would like to adjust the pedal so that 100% is reached earlier. Is there a way to adjust this (e.g., with an adjustment screw)?
Can I actually shorten the pedal stroke? (It seems very long to me).
'Thank you very much!'
Translated on 19-10-2026, 9:48.
