Passat TDI: Diagnosebuchse - Standort & Anleitung
haehnlein
Post05-12-2002, 13:48    Subject: Passat TDI: Diagnosebuchse - Standort & Anleitung Quote
Hi!
Please don't hit me!!!!!!!
I just used the search function on the forum and database to try and locate the OBD port in my Passat TDI 1Z, but I couldn't find it anywhere. Where is it supposed to be? I'm new to using VAG-COM!
Someone from VW told me that the connector is located under the cover of the light switch, but I couldn't remove it even with gentle force. If that's the right place, how do you get that cover off? The "How-to" guide doesn't say anything about it!
Thank you in advance icon_redface.gif icon_redface.gif icon_redface.gif icon_redface.gif.
Best regards, Christian.
Translated on 06-08-2026, 17:02.
DocSnydor
Post05-12-2002, 14:26    Subject: Passat TDI: Diagnosebuchse - Standort & Anleitung Quote
It's located directly between the radio and speedometer, underneath the left center air intake nozzle. It's under a small plastic cover. If you have climate control/thermotronic, the interior temperature sensor is located there.
So, it's on the right side of the steering wheel, not on the left where the light switch is.
Best regards.
David.
Translated on 06-08-2026, 17:04.
haehnlein
Post05-12-2002, 15:37    Subject: Passat TDI: Diagnosebuchse - Standort & Anleitung Quote
Hi David!
Finally found it!!! Thank you very much!
The socket is very loose inside (well, it's only been maintained according to the VW service booklet), and my OBD-II connector is a bit too wide for the frame -> so, time to improvise again...
I notice more and more each day that this box was a complete mistake... icon_cry.gif
Translated on 06-08-2026, 17:05.
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat MKB AVB: Fuel Leak Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diagnosebuchse Audi A4 Diesel Engine Technology
No new posts MAN Diagnostic Socket 37-Pin On-Board Diagnostics (OBD)
No new posts Activate GRA on a Passat manufactured in 11/97 On-Board Diagnostics (OBD)
No new posts Passat 3C: Multifunction Display Upgrade On-Board Diagnostics (OBD)
