Kühlwassertemp. bei "defekter" AGR | Posts 16+
Go to page: Previous  1, 2
Gremlin
Post27-11-2002, 17:48    Subject: Quote
Let's get back to the topic of the German Agricultural Support Program (Agrarflächenentwicklungsförderung).
My ALH actually warms up slower when the EGR is defective. The amount of exhaust gas at partial load is not insignificant, and a considerable amount of heat is apparently dissipated through the exhaust cooler. And, of course, it runs with more knocking when the EGR is faulty. If you set the exhaust gas ratio to maximum via adaptation, it suddenly runs very smoothly icon_smile.gif.
CU Gremlin.
Translated on 18-08-2026, 22:04.
werwolf07
Post09-12-2002, 11:55    Subject: How to: A Detailed Guide Quote
@ gremlin:
Could you please explain the adaptation channels and higher exhaust gas content in more detail? My engine ('AGR' without EGR) is knocking quite a bit, so what can be done to make it quieter?
Translated on 18-08-2026, 22:05.
Gremlin
Post09-12-2002, 18:36    Subject: Quote
Okay, so this only works if the EGR system is active.
In adaptation channel 3, you can adjust the ratio of exhaust gas recirculation (EGR). Setting it to maximum increases the amount of recirculated exhaust gas, which significantly raises the temperature level at idle. This can make even a TDI engine run smoothly, almost like an old-fashioned diesel.
I suspect that he will also fail in the same way.
CU Gremlin.
Translated on 18-08-2026, 22:06.
Avatar-Jan6K
Post09-12-2002, 18:39    Subject: Quote
"Hi Gremlin,"
What is the typical operating range here? Can that value also be set to zero, essentially disabling the EGR system via software?
January.
1Z5 CFHF / AHB H4D
Translated on 18-08-2026, 22:07.
Gremlin
Post09-12-2002, 18:55    Subject: Quote
No, the area is quite small...
I don't have any values readily available right now (and it's freezing outside, so I'm not going out), but it's similar to the idle setting. It goes up and down a bit. You can hear it quite clearly when you set it to maximum. If I recall correctly, the value is something like 33768...
CU Gremlin.
Translated on 18-08-2026, 22:08.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
