Adjust Kilometer Reading | Odometer Correction
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
acuransx
Karma: +1 / -1   Thank you, like it!
2002 Volkswagen Golf
Post24-09-2006, 12:19    Subject: Adjust Kilometer Reading | Odometer Correction Quote
Hello...
I have a car with 0 km on the odometer (brand new). Is there a way to change this value to 120,000 km using VAG-COM or another program?
"Regarding the alarm system, do I need to have it re-programmed, or does it work automatically?"
I would really appreciate a response.
Translated on 01-08-2026, 1:26.
mullemaus
Post24-09-2006, 13:50    Subject: Adjust Kilometer Reading | Odometer Correction Quote
Please do us all a favor and read the forum posts. The VAG-COM user manual from Ross-Tech also explains how to do this clearly. If you don't have a manual, you can download one from your distributor's website.
Translated on 01-08-2026, 1:27.
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Can ABS only be deactivated when the vehicle is stationary? On-Board Diagnostics (OBD)
No new posts ABS/MSG Data: Where to Read Kilometer Stand? On-Board Diagnostics (OBD)
No new posts BMR Beeping While Stationary: Troubleshooting Diesel Engine Technology
No new posts KM Stand Control: Check & Monitor On-Board Diagnostics (OBD)
