Was genau bringt eingentlich die Vorwärmung beim PÖLen ? | Posts 32+
Go to page: Previous  1, 2, 3
Nebelwerfer_TDI
Post15-09-2006, 9:05    Subject: Quote
With the TDI Graph, you can set it to the upper limit if you want it to engage early.
Screws: If you have a one-piece impeller (which you can tell by looking at it), then (this needs to be removed, I'll finish writing it later icon_wink.gif).
hollari
Post26-09-2006, 13:38    Subject: Quote
Okay. I had the pump recalibrated.
It was significantly delayed.
(After the last timing belt replacement, there were no problems...)
(I didn't take advantage of those opportunities back then, so I just let them pass.)
At icon_smile_thumb_up.gif5 degrees and 50% relative humidity, my engine starts now.
completely normal, just like with 100% diesel.
(Also without any tricks, like extra glow...)
I thought something like that would be noticeable with diesel engines too.
What else I've noticed is:
at speeds of 70-80 km/h in 5th gear (i.e., 1500-1700 RPM).
There was a slight stutter or hesitation when the accelerator pedal was pressed about halfway.
I would rather say 'swing' in the context of acceleration.
It's gone now!
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts H&R Anti-Roll Bar for VW Golf 4 4Motion: Does it work? Transmission, Chassis, Body & Interior
No new posts Drum brakes on my Polo 9N3 are driving me crazy! Transmission, Chassis, Body & Interior
No new posts 16V TDI: Location of Cylinder Head Crack Diesel Engine Technology
No new posts What are the benefits of a lift kit? Transmission, Chassis, Body & Interior
