Leaky Oil Cooler: What to Do?
vikinger
Post24-02-2003, 6:03    Subject: Leaky Oil Cooler: What to Do? Quote
I'm having the following problem:
After an accident involving my V6 TDI (AKN) engine, I had to remove the oil cooler to replace the power steering pump bracket. Now, I can't seem to get it sealed properly. I've already replaced the gasket between the cooler and the cover, but the gasket between the cooler and the engine block is not sold separately. Does anyone know of another solution besides having to buy a whole new oil cooler just for that small gasket? It's almost a case for Autobild magazine again... a gasket that costs 20 cents, and now I have to replace the entire oil cooler, which costs almost 150 euros.
Eagle.
Translated on 28-09-2026, 8:12.
Marzocchi
Post27-09-2006, 17:52    Subject: Leaky Oil Cooler: What to Do? Quote
Perhaps with a good sealant, like the kind used to seal valve covers or oil pans?
Golf IV - ALH - Erstzulassung 9/99
Translated on 28-09-2026, 8:13.
Nebelwerfer_TDI
Post27-09-2006, 18:23    Subject: Leaky Oil Cooler: What to Do? Quote
See if you can fit some O-rings in there. The old oil coolers had them too. Just make sure they are oil-resistant and don't get pushed out (by being overtightened).
'Sealant? Well, maybe a thermosilikon (the dark red one) could work, but I would definitely make sure the surfaces to be sealed are completely free of grease beforehand using brake cleaner, and I would only tighten the radiator completely after the silicone has fully cured (so that it's compressed and can't move).'
No new posts Audi A4 documentation: Oil leak at the oil cooler Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B2 CV Joint Leak: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BKC Engine Oil Cooler: Buy Now! Diesel Engine Technology
No new posts Oil Cooler Upgrade for ALH Engine Problems Diesel Engine Technology
No new posts Hooray, it's working now! Diesel Engine Technology
No new posts Pierburg MAF Sensor: Now Officially for TDI Engines Diesel Engine Technology
