Warme Kupplung rupft | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
bastion
Karma: +6 / -1   Thank you, like it!
Post22-09-2006, 12:18    Subject: Quote
A few days ago, I inspected my gearbox through a viewing hole, but I couldn't find one.
Does my CPC now actually have a ZMS?
A4 Avant 08/01 AWX 05/08-
Translated on 17-07-2026, 19:03.
makrospex
Post22-09-2006, 13:21    Subject: Quote
Whether your transmission (is CPC the transmission code, or not?) has a dual-mass flywheel is indicated in the technical article database.
It's strange that you can't find the inspection hole. Could you take a picture of the clutch/transmission area and post it online somewhere? Then link it here. That would help us a lot. Unfortunately, I don't have a digital camera right now, otherwise I would take a picture of my engine bay and mark the location of the inspection hole.
macro
Translated on 17-07-2026, 19:04.
bastion
Post22-09-2006, 13:50    Subject: Quote
I just checked the database and there is no corresponding ZMS entry for it.
Yes, CPC is the GKB. I will upload a photo in the next few days.
Translated on 17-07-2026, 19:05.
makrospex
Post22-09-2006, 15:57    Subject: Quote
Okay, I'll get an email when your next post is live anyway...
bastion
Post07-11-2006, 9:02    Subject: Quote
Okay, the problem is solved.
The engine mount on the gearbox support was crooked. This caused the engine to swing excessively when engaging the clutch, especially when the engine mounts softened due to heat, which in turn made the clutch start to jerk.
Translated on 17-07-2026, 19:06.
makrospex
Post07-11-2006, 9:46    Subject: Quote
Thank you for the feedback!
macro
BM
Avatar-BM
Post07-11-2006, 16:12    Subject: Quote
The motor mount on the gearbox support was crooked. Therefore, when engaging the clutch, if the motor mounts became soft due to heat, the motor could swing so violently that the clutch started to jerk.
You never stop learning. However, the engine's tendency to tilt (the "Bonanzaritt" effect) should have been noticeable.
Let's see how long this current situation lasts.
3B5 AJM
Translated on 17-07-2026, 19:07.
bastion
Post07-11-2006, 16:44    Subject: Quote
Well, when shifting gears, there was usually a jolt (depending on the speed and distance). About one second after I took my foot off the accelerator.
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3, Quietschgeräusche Kupplung Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 81KW - Kupplung rutscht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Slipping: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Clutch Slipping? Common Causes & Solutions. Diesel Engine Technology
No new posts Clutch Slipping After 7k Miles: Why? Diesel Engine Technology
No new posts Clutch jerks when starting, especially in warm weather (A... Transmission, Chassis, Body & Interior
