Engine Repair: Vibration Problems - Find a Mechanic
Dieselmike
Post23-11-2006, 19:53    Subject: Engine Repair: Vibration Problems - Find a Mechanic Quote
My AHF (presumably a specific component or system) causes strong vibrations, which naturally also leads to corresponding driving noises. I've heard that VW has very high manufacturing tolerances, and that this can cause some engines to vibrate more than others.
One method would be to precisely balance the crankshaft and to balance and angle the pistons.
Does anyone have any experience with this, or know a specialist? The engine is installed in a T3 and doesn't have a dual-mass flywheel. Could there be other causes for this?
Best regards, Mike.
Translated on 01-11-2026, 9:45.
bastion
Karma: +6 / -1   Thank you, like it!
Post23-11-2006, 21:19    Subject: Engine Repair: Vibration Problems - Find a Mechanic Quote
Is the engine mount broken or is the flexible pipe damaged?
A4 Avant 08/01 AWX 05/08-
Translated on 01-11-2026, 9:46.
Post23-11-2006, 21:58    Subject: Engine Repair: Vibration Problems - Find a Mechanic Quote
I would also suspect the engine mounts.
What is piston tilt?
dieter
Karma: +13 / -0   Thank you, like it!
Post24-11-2006, 10:03    Subject: Engine Repair: Vibration Problems - Find a Mechanic Quote
I highly doubt the problem lies with the engine itself, but rather with the modifications that were made. There are plenty of possibilities there:
- missing content management system (CMS)
- Motor or gearbox mount.
- Exhaust system (with or without a flexible pipe?)
If you want more help, more information is needed.
What kind of bus is it exactly?
Who carried out the renovation, and when?
When did it first occur, and under what circumstances?
etc.
Greetings,
dieter
T3 syncro 16 AFN
Translated on 01-11-2026, 9:47.
Dieselmike
Post24-11-2006, 15:53    Subject: Engine Repair: Vibration Problems - Find a Mechanic Quote
Okay, so the engine is installed in a VW T3. It's always had that rumbling noise. It hasn't had any other modifications. We've tried everything: soundproofing, driving without an exhaust, suspending the engine with a chain, installing a dual-mass flywheel, etc. Now, I'm trying to figure out what within the engine itself could be causing the vibrations, because that's the only thing that could possibly be the issue.
It doesn't necessarily mean angling the piston, but rather angling the connecting rod, specifically so that the small and large connecting rod eyes are perfectly aligned vertically above each other.
Translated on 01-11-2026, 9:49.
syncro peter
Post25-11-2006, 20:16    Subject: Engine Repair: Vibration Problems - Find a Mechanic Quote
Enjoy your meal!
'Who carried out the conversion? Do you know what parts were used, specifically in the engine mount/bearing area?'
Translated on 01-11-2026, 9:50.
Dieselmike
Post28-11-2006, 10:01    Subject: Engine Repair: Vibration Problems - Find a Mechanic Quote
I did the conversion myself, and to reiterate, this is specifically about the engine itself; everything else can be ruled out.
christians
Post28-11-2006, 19:17    Subject: Engine Repair: Vibration Problems - Find a Mechanic Quote
Is the engine still original, or has someone possibly tinkered with it before, perhaps even installing the pistons incorrectly? At least in some 4-cylinder engines, not all the pistons are the same. (Search function - there was something about this here before).
Gruß Christian
BM
Avatar-BM
Post28-11-2006, 20:28    Subject: Engine Repair: Vibration Problems - Find a Mechanic Quote
My AHF (Antivalent Headphone) causes strong vibrations, which naturally also leads to the corresponding driving noises.
I have heard that VW has very high manufacturing tolerances, and that this causes some engines to vibrate more than others. }
If it's vibrating strongly, like an orbital sander, even at relatively low speeds, it's unlikely that fine balancing will fix the issue. It's possible that one of the pistons has a significant weight imbalance, or that the problem lies elsewhere.
I only have experience with balancing from my old GTI 1.8, where I balanced the entire crankshaft and the crankshaft with flywheel were finely balanced. It was quite remarkable that the difference between the lightest and heaviest components was so noticeable.
(The piston, connecting rod, and valve cover assembly) weighed approximately 12-15 grams. The result of all this was a very smooth-revving engine (around 7000 RPM at the time).
with hardly any trace of vibration.
3B5 AJM
Translated on 01-11-2026, 9:52.
Dieselmike
Post29-11-2006, 9:25    Subject: Engine Repair: Vibration Problems - Find a Mechanic Quote
I thought so too. I remember when our special cross-country vehicle had its E30 M3 engine meticulously balanced. The engine speed was then 9200 RPM, but the entire engine was also completely rebuilt by the tuner.
Thank you for the information, BM.
Translated on 01-11-2026, 9:53.
No new posts Documentary about vibrations starting at approximately 12... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Vibration Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vibration at Acceleration: Causes & Fixes General Tips
No new posts Small Battery Box for ASZ - Save Space! Transmission, Chassis, Body & Interior
No new posts @ Tim 27 regarding pump tuning Diesel Engine Technology
No new posts @Thomas regarding Lupo Diesel Engine Technology
No new posts OBD Experts: Speedometer Issues & Solutions On-Board Diagnostics (OBD)
