2-Takt Diesel die 2. | Posts 32+
Go to page: Previous  1, 2, 3
Post30-11-2006, 8:39    Subject: Quote
...with a construction height of 15.1 meters, a length of 29 meters, a lifting capacity of 2.66 meters, and a bore diameter of 0.98 meters... well, that should definitely produce some power.
For those who are considering the possibility of a retrofitted engine ( icon_wink.gif ), the K98MC Mk6, which weighs a good 2446 tons, is made by MAN B&W and can rotate the crankshaft 94 times per minute.
Translated on 12-09-2026, 21:38.
mahk
Avatar-mahk
Post30-11-2006, 9:07    Subject: Quote
Somewhere, we had this one before, didn't we? http://people.bath.ac.uk/ccsshb/12cyl/
Unfortunately, the pictures are "only" of the 10-cylinder version; it's probably also available with 14 icon_exclaim.gif.
http://people.bath.ac.uk/ccsshb/12cyl/rta96c_crank.jpg
... with a shaft leading into the crankcase - tsss.
Typ89 SB: 05/2000 120.000km - 01/2005 295.000km (unfall)
B5 Avant AEB 07/2005 166.000km ([email protected]) - 07/2007 195.000km (verkauft)
1K BMM: 03/2011 120.000 km - aktuell
Translated on 12-09-2026, 21:39.
Stef@n
Post30-11-2006, 12:15    Subject: Quote
@ mahk
What's even more interesting is the fact that these engines run at a minimum speed of approximately 15 RPM. You almost expect them to stall at any moment.
We were using the 9K90 MC-C back then. icon_biggrin.gif It consumed 150 tons of HFO per day.
Translated on 12-09-2026, 21:40.
Avatar-Jan6K
Post30-11-2006, 22:44    Subject: Quote
a 10-cylinder two-stroke engine at 15 RPM... that means 150 ignitions per minute, or 2.5 per second. You should definitely be able to hear each one individually... and the fuel injection amounts are probably not measured in milligrams, but rather in buckets or something like that icon_wink.gif.
The torque really has to be immense, even at idle.
Jan.
1Z5 CFHF / AHB H4D
Translated on 12-09-2026, 21:41.
Post01-12-2006, 8:34    Subject: Quote
All MAN B&W two-stroke engines operate at only one maximum speed, which varies depending on the model, ranging from 90 to 104 revolutions per minute (RPM). The lowest maximum speed is 76 RPM for the S80 MC. Operating at a lower speed is not economically viable because these engines are designed for a specific power range. Of course, they can operate at a slightly slower speed, for example, in port operations. In such cases, the fuel is often switched from heavy fuel oil to a more fluid fuel to prevent excessive smoke. Consequently, it takes a very long time to reverse the direction of the engines. The engine must be stopped completely. Since it is directly connected to the shaft, a brake is required to stop the shaft and propeller. Even when the ship is moving at a speed of 10 knots, significant forces are involved. To engage reverse, the engine is started in the opposite direction using compressed air.
Consumption... yes, the "Eimer" (likely a product name) seems to fit, with 171g/kWh at maximum power output. At 87220 (likely a setting or value), that would be... hmm... roughly 183g per ignition, right?
But with a lifting height of 2.6 meters, you can definitely inject for a good amount of time...
Translated on 12-09-2026, 21:43.
Stef@n
Post01-12-2006, 9:47    Subject: Quote
Yes, that's about right... a modern ship diesel engine has a specific fuel consumption of approximately 170 g/kWh.
The entire system is called a fixed-pitch propeller. And you're right, the engine is steered using compressed air.
For smaller engines, a gearbox is often located behind the engine, and adjustable propellers are positioned at the rear. This allows for different performance characteristics depending on the angle of the blades. It's a great system: the engine always runs at a constant speed, and the speed-dependent load is regulated by the amount of fuel being used.
In some B&W two-stroke marine diesel engines, there are designs with 12 cylinders in a V configuration. I can only say: have fun with the piston removal! icon_redface.gif
Translated on 12-09-2026, 21:45.
cetano
Avatar-cetano
Post17-12-2006, 13:48    Subject: Quote
I have a ... 1-cylinder, 2-stroke, opposed-piston diesel engine, 12 horsepower, manufactured by Junkers in 1931, and it runs and runs... It's installed in a homemade tractor built in 1954, which I completely rebuilt myself. It's indestructible. It always starts without glow plugs, even in -15°C temperatures, using a hand crank. If everything else fails, this one always works.
I still have some documents if anyone is interested.
see also here.
http://www.ludwig-saenger.de/1642/1957.html
http://motorenmuseum.de/13807.html
Kfz-Prüfstelle des TÜV Rheinland/FSP Saalfelder Höhe in Thüringen im grünen Herzen Deutschlands.
Wir lieben Diesel, vor allem alte..
Sommer: Oldtimer W124 2,5 Saugdiesl 90 PS Bj 87, Winter: Golf4 4Motion TDI AGR
Translated on 12-09-2026, 21:46.
Back to top Profile PM Email
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Are there two-stroke diesel engines? Diesel Engine Technology
This topic is locked, you cannot edit or reply. 2-Stroke Oil: Problems, Solutions, and Tips Diesel Engine Technology
No new posts Climatronic Compressor Cycling Every 2 Seconds (Vento 97) Transmission, Chassis, Body & Interior
No new posts Diesel 2.0 170 HP: Specs & Performance Diesel Engine Technology
