Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount
ollli
Post16-12-2006, 16:06    Subject: Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Quote
Hello, diesel mechanics.
I have a question for you. It's about my Golf 2 GTD. Yesterday, I was trying to install brake calipers from a Golf 2 16v. I noticed that the brake calipers didn't have a proper guide at the bottom, where they attach to the brake pad holder. Is it possible that the Golf 2 GTD and the Golf 2 16v have different brake caliper holders? Previously, my GTD had standard brake discs, and now I have ventilated ones.
I would really appreciate your response.
Olli.
Translated on 14-10-2026, 22:38.
Post17-12-2006, 10:44    Subject: Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Quote
Hi.
I'm not entirely sure, but the GTD should have the 13" VW2 brake system, while the GTI 16V should have a 14" system.
If I were to do it, I would rebuild everything from scratch and not create a hybrid system. Brakes are not entirely unimportant!
Translated on 14-10-2026, 22:39.
Held467
Post17-12-2006, 11:02    Subject: Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Quote
Hello.
The 16V system is available in the 239 and 256 models. The 239 will fit your vehicle as you already have it. However, for the 256 model, you will need different wheel bearing housings because the mounting points for the saddle carrier are different.
Dirk
Translated on 14-10-2026, 22:40.
Post17-12-2006, 14:40    Subject: Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Quote
Oh.
Did both happen?
I meant 239 mm corresponds to 13" and 256 corresponds to 14".
Sorry for the inaccurate submissions. It's been quite a while.
Soon, I will have to consider sizes of 16" (312mm) and 17" (345mm) icon_wink.gif.
Translated on 14-10-2026, 22:41.
ollli
Post17-12-2006, 22:01    Subject: Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Quote
Hello.
First of all, thank you for your efforts.
I'll check with VW; they have a list for that. I definitely want to make sure the brakes are okay.
Olli.
Translated on 14-10-2026, 22:42.
Held467
Post17-12-2006, 22:20    Subject: Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Quote
What's written on the saddles?
ollli
Post18-12-2006, 18:26    Subject: Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Quote
Hello.
I can't say exactly what's written on it right now. They are ATE parts for a Volkswagen Golf 2 16V.
The vehicle is at my parents' place.
PS: I called the mechanic, and he told me that there are different brake caliper adapters available for the Golf 2.
Olli.
Translated on 14-10-2026, 22:43.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 2.0 TDI 4-Motion rear brake caliper Transmission, Chassis, Body & Interior
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Is it possible to retrofit a VE-ESP system from a Golf 4 ... Diesel Engine Technology
