Odometer replacement
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
manx
Post26-10-2003, 21:19    Subject: Odometer replacement Quote
Hey everyone,
Does anyone know if the speedometer/tachometer from a 2000 Golf TDI (ALH) can be swapped with one from a 2002 model, such as a Sport Edition?
What happens if a device with Multi-Factor Authentication (MFA) is installed when previously there was no MFA enabled? Will the 'standard displays' still function?
And finally, does the steering wheel need to be removed when changing [something]?
'On eBay, these kinds of instruments are constantly being offered for sale, so does anyone have any tips before I make a mistake?'
Translated on 17-07-2026, 22:36.
mersente
Post14-02-2004, 22:49    Subject: Odometer replacement Quote
Hello, I can tell you the following about this: After replacing your instrument cluster, you need to reprogram your keys and adapt the instrument cluster to the engine control unit. Additionally, you also need to inform the system whether your car has ABS or not.
It's probably best to leave that alone, or do you know if that item from eBay is still in good condition?
Translated on 17-07-2026, 22:38.
davie
Post22-12-2006, 15:36    Subject: Audi 100 1992 - Replacing the speedometer Quote
Hello!
I want to replace the entire instrument cluster in my 1992 Audi 100 2.5 TDI with engine code AAT.
The old one has an analog speedometer, while the new one has a digital speedometer.
Can I install this, or can I also install a combination instrument with Multifunction Display (MFA)?
Thank you.[/b]
Translated on 17-07-2026, 22:39.
No new posts VW Golf 4: Replace Analog Speedometer with FIS Display Transmission, Chassis, Body & Interior
No new posts Speedometer Calibration: Accurate Speed Reading Transmission, Chassis, Body & Interior
No new posts RPM display for TDI engine Transmission, Chassis, Body & Interior
No new posts Program the speedometer! Diesel Engine Technology
