Octavia Won't Start: 110HP Engine Troubleshooting
Rip-J
Post26-08-2005, 16:08    Subject: Octavia Won't Start: 110HP Engine Troubleshooting Quote
I'm having the following problem:
My Octavia with a 110hp TDI engine sometimes doesn't start, or it sometimes stalls while driving. I've already read the error codes, and the results are:
Control unit part number: 1J0 907 379 H.
Component and/or version: ABS/EDS 20 IE CAN 0001
Encoding: 13304
Workshop code: WSC 31480.
1 error code found.
01314 - Engine Control Unit (ECU)
49-10 - No communication - Intermittent.
What I also noticed is that the error occurred at very warm temperatures. Usually, it would resolve itself later in the evening. My suspicion was that it might be related to the wire resistance, which could potentially increase at higher temperatures.
Does anyone happen to know the cause of this phenomenon?
Translated on 04-10-2026, 11:42.
Post26-08-2005, 17:38    Subject: Octavia Won't Start: Troubleshooting & Fixes Quote
Have you already checked the article about common mistakes?
Translated on 04-10-2026, 11:44.
Rip-J
Post26-08-2005, 19:08    Subject: Octavia Won't Start: 110HP Engine Troubleshooting Quote
Yes, I found the reference to WFS there. Is it possible that there's an entry about it in the ABS control unit?
Post26-08-2005, 19:10    Subject: Octavia Won't Start: 110HP Engine Troubleshooting Quote
Wrong target... what about "109"?
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia Starting Problems (AGR Engine) Diesel Engine Technology
No new posts Octavia Starting Problems: ESP Repair Not the Issue? Diesel Engine Technology
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
No new posts Audi A4 Heating Problem: Not Getting Warm (1997) Transmission, Chassis, Body & Interior
