ABS and brake warning light, error codes 00290 00688
Klausel
Post11-07-2005, 21:41    Subject: ABS and brake warning light, error codes 00290 00688 Quote
Hello!
Volkswagen Golf III AFN, manufactured in 1997, model year 1998, with 147,000 km (approximately 91,000 miles).
"For the past few days, I've been seeing the ABS warning light and getting this error code:"
00290 (Rear left speed sensor) 35-00.
Initially intermittent, now constant.
Okay, it looks like I'll have to replace (or have replaced) a sensor again, but today, in addition to the ABS light, something else happened.
Sometimes, the brake warning light comes on for a few seconds when starting the engine.
and subsequently, an additional error code appeared:
00668 (Supply Voltage Terminal 30, 16-10 Signal - Outside Specifications)
Okay: On-board voltage at terminal 30 is outside the tolerance range.
The error database indicates "Interruption, short circuit to positive or ground."
Battery voltage is good (12.5V after a long period of inactivity), and the relays seem to be at a normal temperature.
What is that likely to be?
Thank you for your responses.
Greetings, Klaus.
Translated on 21-07-2026, 17:46.
Post11-07-2005, 22:19    Subject: ABS and brake warning light, error codes 00290 00688 Quote
/viewtopic.php?t=7901 icon_question.gif
Translated on 21-07-2026, 17:48.
No new posts MKB AMF Error Codes: Causes and Effects Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Codes, Causes and Effects for MKB ASZ, AXR, ATD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes 19804/P3348 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Error 00290: Causes and Fixes On-Board Diagnostics (OBD)
No new posts ABS error codes 00290 and 00287 - 1999 Ibiza Electrical Systems, Vehicle Electronics, Multimedia
No new posts Fehlercodes ? On-Board Diagnostics (OBD)
No new posts ASV Error Codes: Troubleshooting & Solutions Diesel Engine Technology
