ZV audi A8
opelfreak
Post04-09-2005, 20:58    Subject: ZV audi A8 Quote
Hello!
I am a new member, and I am having problems with my car. I cannot access the central locking system (ZV) using VAG-COM without a login code, and now I am asking you for help? I'm sorry for my German, I'm from Slovenia, please forgive me!
Audi A8
Born in 1999
2.5 TDI
AFB
Ross-Tech-Support
Post04-09-2005, 23:00    Subject: ZV audi A8 Quote
Is the first question: Which address are you trying to deliver to? #35 or #46?
On the A8 (4D), this is only possible via #35.
Before I continue, let me clarify upfront: a login has nothing to do with this!
The next questions would then be:
1. Which interface (manufacturer/retailer)?
2. What VAG-COM version (version number)?
3. Can I reach other control units?
opelfreak
Post05-09-2005, 9:13    Subject: ZV audi A8 Quote
1. I can't access #35 address, but I need a login code to make any changes.
- I am using the professional system HEX-USB+CAN (USB) from Rainer Kaufmann.
- VAG-COM version 504.1
- I can access all the control units, but I cannot perform adaptation without a login code.
For the motor, a valid login code is 11463, but for the central locking system, it is invalid.
Post05-09-2005, 11:58    Subject: ZV audi A8 Quote
11463 is not _any_ login, that is the GRA activation code.
Are you really sure about what you're doing?
Ross-Tech-Support
Post05-09-2005, 16:05    Subject: ZV audi A8 Quote
dieselmartin wrote:
11463 is not _any_ login code for the GRA activation code.
And it only works with some engine control units, nowhere else.
No, isn't it?
The central vehicle control unit in this vehicle does not support adaptation.
How do you even come to the conclusion that it should do this?
Say goodbye to the idea that login codes can do everything; that's simply wrong. The Login/Encoding-II function is necessary for numerous stories, but not in the way many think, i.e., to activate "dead" (grayed out) buttons.
opelfreak
Post05-09-2005, 18:51    Subject: ZV audi A8 Quote
but with the Passat, adaptation of the login code for the central heating system is possible!
OK, I don't want to bother you, I'm just having trouble with the central locking system.
Problem:
If the vehicle is locked, no confirmation will be received via flashing lights or horn.
When opening, a confirmation is given by blinking 3 times.
I need a solution, I want it like this:
- When the light flashes 3 times and the horn sounds.
- When opened, it blinks 1x
How should I do this? I've already tried almost everything!
Best regards, Dejan
Ross-Tech-Support
Post05-09-2005, 20:00    Subject: ZV audi A8 Quote
opelfreak wrote:
but with the VW Passat, it's possible to adapt the central ventilation system with a login code!
No, even with the Passat, no login code is required for customization.
Besides, an A8 is not a Passat.
opelfreak wrote:
Upon opening, a confirmation is provided through a 3x blink.
How should I do this, I've already tried almost everything!
On the A8 (4D), these settings are implemented using coding.
What is the CURRENT coding of the control device?
opelfreak
Post05-09-2005, 20:15    Subject: ZV audi A8 Quote
encoding is now 13130!
Ross-Tech-Support
Post05-09-2005, 20:27    Subject: ZV audi A8 Quote
Your current encoding is determined by:
+00002 - Warning light when DWA is activated
+00008 - Activate the Theft Alarm System (DWA)
+00064 - Comfort locking/unlocking via remote control
+00256 - Rear Door Logic (DWA)
+00512 - Warning flash when closing via remote control
+04096 - Warning light when opening via remote control
+08192 - Activate remote control
= 13130
Therefore, the functions you requested are, in principle, already active.
Activating the horn is not possible with this model.
Additionally, the number of blink cycles cannot be changed.
The conclusion would be that there is an error somewhere, for example, Door contacts.
No new posts Audi 1Z LLK: Coolant Replacement Guide Diesel Engine Technology
No new posts log 3-8-11 audi A6 lmm defekt? Upload
No new posts logarithm calculation for LMM on Audi A6 Upload
No new posts motorprobleme audi 2.5 tdi BDG On-Board Diagnostics (OBD)
