VAG-COM: No Instrument Cluster Reading Possible
Mettzger
Post07-08-2005, 12:25    Subject: VAG-COM: No Instrument Cluster Reading Possible Quote
Hi, I'm trying to read the instrument cluster of a 2001 Golf IV 2.0l Cabrio to reset the service interval. It's worked well with our Lupo and T4 before. But with the Golf, I can't access address 17 at all. It's not readable! Am I doing something wrong? I've really searched, but I couldn't find anything about this.
Best regards, Mettzger.
Translated on 11-09-2026, 11:22.
Post07-08-2005, 13:46    Subject: VAG-COM: No Instrument Cluster Reading Possible Quote
Which tool and software version are you using?
IMHO, there were often problems with the connector of the instrument cluster (loose connection).
Translated on 11-09-2026, 11:23.
goettmann
Post07-08-2005, 15:17    Subject: VAG-COM: No Instrument Cluster Reading Possible Quote
GOLF IV Convertible?
That's new to me!
While there was a Golf 3 Cabrio with a G4 appearance, the technology underneath the body panels was all G3, and the control units were not diagnosable.
Mettzger
Post07-08-2005, 15:41    Subject: VAG-COM: No Instrument Cluster Reading Possible Quote
I'm using VAG-COM 409.1, which came with my hobby kit.
Translated on 11-09-2026, 11:24.
Post07-08-2005, 16:17    Subject: VAG-COM: No Instrument Cluster Reading Possible Quote
Okay, and what is your vehicle's model designation?
If the value is '1H', then goettmann is correct, and nothing can be done under address 17.
Mettzger
Post07-08-2005, 16:28    Subject: VAG-COM: No Instrument Cluster Reading Possible Quote
Okay, that's a shame, but good to know. Thanks for the information!
vagtuning
Post08-08-2005, 17:54    Subject: VAG-COM: No Instrument Cluster Reading Possible Quote
I would say he should look for and find a '1E' instead of a '1H' in the vehicle type and in the chassis number.
Translated on 11-09-2026, 11:25.
AudiS3
Post15-08-2005, 16:03    Subject: VAG-COM: No Instrument Cluster Reading Possible Quote
Or try it with version 3.XX of the VAG Com software?
Post15-08-2005, 16:54    Subject: VAG-COM: No Instrument Cluster Reading Possible Quote
Hi.
AudiS3 wrote:
or try it with the 3.XX VAG com version?!
That definitely isn't the reason.
Let's see if Mettzger has anything else to say about his vehicle type.
If the AI is not capable of making diagnoses, then it simply isn't.
Translated on 11-09-2026, 11:26.
Ross-Tech-Support
Post15-08-2005, 19:22    Subject: VAG-COM: No Instrument Cluster Reading Possible Quote
He doesn't need to say anything.
A Golf 4 Cabriolet is technically a Golf 3, and this applies to the instrument clusters as well.
Therefore, no diagnosis is possible, and the vehicle type is 1E, not 1H.
WarLord
Post26-08-2005, 21:34    Subject: VAG-COM: No Instrument Cluster Reading Possible Quote
therefore, no diagnosis possible, and the vehicle type is 1E, not 1H.
Okay.
Best regards, WarLord.
Translated on 11-09-2026, 11:27.
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Polo 9N: Longlife oil not possible Electrical Systems, Vehicle Electronics, Multimedia
No new posts Car won't start, headlights on? (Normal?) Transmission, Chassis, Body & Interior
No new posts Unable to save after update On-Board Diagnostics (OBD)
No new posts Read Binary File: Software Data Extraction On-Board Diagnostics (OBD)
