Headlight Alignment Issue Superb 3U
TDI-Vielfahrer
Post31-08-2005, 10:45    Subject: Headlight Alignment Issue Superb 3U Quote
Hello everyone.
I'm immediately encountering a problem that I've been desperately trying to fix for the past two days.
I own a Skoda Superb Elegance 3U 1.9 TDI, manufactured in November 2002, with bi-xenon headlights.
For the past 4 weeks, the vehicle has intermittently displayed a 'headlight failure' message after ignition, and for the past 2 days, it has appeared every time the ignition is turned on. The error code in the diagnostic memory indicates 'headlight range not adjusted.' The control unit (STG) 55 has a coding of '5' with a WSC of 73430 - 4Z7907357. Using VAG Com, I cannot access the manual adjustment or the learning adjustment functions with this coding. When I change the control unit coding to '7,' as used in the Passat 3B, I can access the manual and learning adjustment functions, but nothing happens afterward (the headlights were manually adjusted for approximately 3 minutes, and then the system was left in the learning phase for over 5 minutes). Although the error code disappears afterward, the headlights no longer adjust automatically after the engine starts. So, I reverted to the coding of '5,' and the error code immediately reappears. The headlights then attempt to adjust themselves after ignition, but they move down to the bottom limit and then back to a middle position. It seems like almost everything is working correctly, but this error code keeps reappearing and cannot be cleared.If one wants to clear the error, the headlights also move completely down to the lowest position (the servo motors can be heard slipping) and then to a middle, pre-set height.
I hope someone can give me a tip on how to fix this error.
Best regards and thank you,
Michael.
I just found the problem myself. The load sensor on the rear axle was out of its adjustment range. Unloaded: TARGET: 1.9-2.3V; ACTUAL was 1.85V. Front axle: TARGET: 2.3-2.9V; ACTUAL = 2.45 volts.
It seems that the recoding to 7 (Passat 3B front-wheel drive with dynamic headlight range control) and then pressing 'OK' was likely a coincidence, as both values were probably within the valid range.
You can find the actual values in the control unit, specifically in measurement group 2, section 8, with the first value representing the front and the second value representing the rear.
Adjusting the sensors is probably not intended, as the only way to fix it is to use a large pliers to bend the brackets.
Michael.
Translated on 31-10-2026, 13:27.
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Superb Estate (Wagon), 2012, Tailgate Actuator Defe... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CAN Error: Not Ready - Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Skoda Superb 1.9 TDI - Clutch Problems:( Diesel Engine Technology
No new posts DPF Questions: Skoda Superb 3U (BSS) Diesel Engine Technology
No new posts Skoda Superb 3U: Fault Codes & Diagnostics On-Board Diagnostics (OBD)
