Semi-pro system review on Alfa
dakoal
Post10-09-2005, 20:15    Subject: Semi-pro system review on Alfa Quote
Since I've been using a semi-professional system from Shop for a few months now, I've been able to help several acquaintances and friends.
Today, a neighbor of an acquaintance approached me and asked if I could take a look at his car.
When I was over there, I saw a car, an Alfa Romeo of some kind, probably from around 2002, a 2.0L 16V model, supposedly with 165 horsepower.
"And then I said, "And where am I supposed to attach the diagnosis?""
He actually found an OBD connector.
I plugged it in, it lit up, and... it worked.
You only need to click on OBD2 (located in the lower left corner of the main menu) in VAG-COM.
And the great thing about it is that you don't need to use "calibration blocks" to record data; you can directly select the data you want (RPM and km/h for the performance meter) and generate a log file.
The sobering reality: 92 horsepower at 5900 RPM and 130 Nm of torque at 3800 RPM.
Subsequently, I checked the LMM values, and they were far too low.
Translation: Air filter has NEVER been changed, even after 135,000 km!!!
So, the Dieselschraubershop interfaces can also be used for other OBD vehicles. I didn't believe it, but it worked.
Have a good evening.
I'm sorry, I can't translate that word because it doesn't seem to be a real word. Could you please provide a different word or phrase?
____________________________________
Audi A6 Avant (C4) 2,5TDIi MKB:AEL, BJ 1995 @ 220tkm //www.spritmonitor.de/image_116461_1.png
VW Golf III 1,9D MKB:1Y, BJ 1995 @ 182tkm R.I.P. (Rest in Poland)
Back to top Profile PM Email
Post10-09-2005, 20:24    Subject: Semi-pro system review on Alfa Quote
Great, thank you for the positive feedback icon_smile.gif.
No new posts Keyless Entry Installation Guide by IN.PRO Troubleshooting & Guides
No new posts P2187 - Bank 1, System Too Lean (Idle) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P2177 - Lean condition system during idle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Alfa 159 1.9 JTDM Diesel Engine Technology
No new posts Intermittent power issue, Alfa 156 2.4 JTD common rail, 1... Diesel Engine Technology
No new posts Report on increasing boost pressure Diesel Engine Technology
No new posts LMM Correction at AEL: A User Report Diesel Engine Technology
