stef
03-12-2007, 8:46 Subject: Seat Alhambra: 90 TDI won't start? Troubleshooting. |
hello forum
"For a few days now, sometimes when I turn off the engine, it continues to run for a few seconds before it shuts off."
The car is a Seat Alhambra, with an AHU engine, manufactured in 1998.
Fix the issue by checking relay 109.
or is there something wrong with the ignition switch?
stef
Translated on 24-10-2026, 8:24.
Profile PM Email |
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
03-12-2007, 14:19 Subject: To be or not to be? |
Hello, the easiest thing would probably be to make the relay accessible, and then, if it doesn't turn off properly, quickly pull the relay.
Or you could try putting in a new one, just to see. I don't think it's the ignition switch. It's either completely off or completely on.
Doesn't he have a bypass valve that isn't working?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 24-10-2026, 8:25.
Profile PM Email Garage |
stef
03-12-2007, 15:27 Subject: Seat Alhambra: 90 TDI won't start? Troubleshooting. |
hello
Okay, I noticed today that the engine keeps running even when I'm letting off the gas!
Okay, it's related to the contactor relay. I've pulled almost all the relays, and it's still staying on.
I will take a very close look at it tonight.
stef
Translated on 24-10-2026, 8:26.
Profile PM Email |
mullemaus Guest
04-12-2007, 0:30 Subject: Seat Alhambra: 90 TDI won't start? Troubleshooting. |
Ignition switch possibly defective?
Translated on 24-10-2026, 8:27.
04-12-2007, 6:26 Subject: Seat Alhambra: 90 TDI won't start? Troubleshooting. |
stef wrote: | So, I noticed today that the sound remains on even when it's supposed to be turning off!!
I will take a very close look at it tonight | .
I suspect there's a short circuit in the wiring leading to the reverse lights, where voltage is being supplied (sporadically?) regardless of the gear selected.
The reverse gear then closes the switch connection to terminal 15, which then no longer requires contact from the ignition switch to carry voltage.
Translated on 24-10-2026, 8:28.
Profile PM Garage |
stef
04-12-2007, 14:14 Subject: Seat Alhambra: 90 TDI won't start? Troubleshooting. |
hello
I found this today.
There was a broken cable connected to the tailgate, all the cables were damaged, and there was a short circuit in the taillights.
Thank you for the tips.
stef
Translated on 24-10-2026, 8:29.
Profile PM Email |
