Unscrew both screws located in the recesses of the cover. The rest is only held in place with clips. On both sides, the trim is still connected to the upper, light-colored panel. However, this panel is also just snapped into place. Be careful when dealing with these connections, as they can become loose over time, and if they do, it won't look as nice afterward. Overall, removing it is quite easy.
Have fun with it!
Translated on 30-07-2026, 2:52.
