pschaefer Blaumann
17-09-2005, 22:39 Subject: Golf 4: Right Front Inner Fender Liner |
"Does anyone have a picture or exploded diagram of the inner workings and surrounding components of the right front fender of a Golf IV? I think that since the workshop replaced said fender, a rubber lip on the headlight and a plastic part at the top where it meets the windshield are missing (both are present on the left side) - but I'm no longer sure what it looked like..."
Translated on 31-08-2026, 12:34.
Blechmann Guest
18-09-2005, 11:54 Subject: Golf 4: Right Front Inner Fender Liner |
'If something is present on the left side, there's a good chance it was also present on the right side at some point.'
'Your trusted VW dealer has the AKTE system for parts sales, which contains every single part that belongs to your car, and you can check (or have someone check) to see if anything is missing or not.'
'I would simply go to the service master and tell him directly that you believe something is missing. Ask him to show you in the AKTE system or on a similar car that you are wrong.'
Translated on 31-08-2026, 12:35.
wutz Blaumann
Joined: 08/13/2004 Posts: 247 Karma: +11 / -1 Location: BRA 2006 Seat Leon Free account, no CAN development support
18-09-2005, 11:58 Subject: Golf 4: Right Front Inner Fender Liner |
Here's a picture of the rubber lip. Unfortunately, I don't have an exploded diagram. However, since the structure is the same on both sides, it shouldn't be a problem to compare the parts. There's a plastic cover for the hood hinge, and on the fender, towards the window, there's another plastic cover clipped to the fender.
The part numbers for the covers are 1J0 819 447E and 448 E. Unfortunately, I no longer remember which one is for the right or left side, but the dealer can tell you.
| Description: |
| File size: |
26.71 KB |
| Viewed: |
2249 times |
Translated on 31-08-2026, 12:36.
Profile PM Garage |
pschaefer Blaumann
18-09-2005, 12:12 Subject: Golf 4: Right Front Inner Fender Liner |
The fender was replaced by a local workshop, that's why I asked here  - Thank you both very much, that helps me a lot!
Greetings and happy (election) Sunday!
Translated on 31-08-2026, 12:37.
wutz Blaumann
18-09-2005, 21:33 Subject: Golf 4: Right Front Inner Fender Liner |
Here's a small tip while you're checking things: There should be two foam blocks in the wheel arch liner, one approximately at mid-height near the door and one centered above the wheel.
Good luck!
Profile PM Garage |
