OBD Connector: Test Functionality & Troubleshooting
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
53i
Post20-11-2006, 12:21    Subject: OBD Connector: Test Functionality & Troubleshooting Quote
Hello everyone!
"Just a heads-up: I absolutely hate electricity, so please don't be surprised by my questions!"
Okay, here's the translation:
"I converted my Corrado to a 1Z engine from a 1996 Passat, including the WFS (engine control module) and an OBD diagnostic connector. Since I've mostly figured out the wiring, I'd like to test the OBD connector to make sure everything is working correctly. The connector itself likely has power, ground, and the diagnostic data line. How can I check if all the wiring is correct? I have a multimeter available, but the person helping me isn't knowledgeable about electrical systems. This is important because a friend needs to use a diagnostic tool to adjust the engine control module and the WFS, and he says the OBD connector needs to be working for that. Power and ground are straightforward (but how do I check them?), but where should I measure the diagnostic data line (the gray-white cable)? Should I measure between the connector, the engine control module, and the OBD connector? How should I connect the multimeter...?"
"Another question: Is it correct that the original instrument cluster from a Passat Estate is connected to the gray connectors in the fuse box? If so, what is its purpose? Is it for resetting the service interval display or something similar?"
Sorry for the silly questions, but my area of expertise is more in mechanics...
Thank you!
Translated on 19-08-2026, 10:03.
Post21-11-2006, 11:12    Subject: OBD Connector: Test Functionality & Troubleshooting Quote
Hmm, where should one even start? Basically, what electrical current is and how to use a multimeter...
http://www.elektronikinfo.de/strom/strom.htm#Allgemeines
http://shop.dieselschrauber.de/product_info.php/products_id/118
The K-line should have a voltage of +12V and be able to draw current with a 100 Ohm resistor connected to ground.
Translated on 19-08-2026, 10:05.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Bremsflüssigkeits-MIL ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts How to check the GRA function? Diesel Engine Technology
No new posts Check cooler fan function? Diesel Engine Technology
No new posts Unterdruckventil für AGR ? Funktion prüfen ? Diesel Engine Technology
No new posts Wie AGR-Funktion prüfen? Differenzdruck Partikelfilter h... Diesel Engine Technology
