KKK Turbo with intake manifold on AFN
Obermeister
Post24-08-2005, 6:11    Subject: KKK Turbo with intake manifold on AFN Quote
The Garrett Turbo GT 1749 VB likely only fits in a G3 if the rear engine mount is modified simultaneously.
Does the same apply to the combination of the intake manifold with the KKK03 turbocharger from the ASZ engine, or can the modification be omitted in this case?
Thank you, best regards.
Master craftsman.
Thomas
Post23-09-2005, 23:46    Subject: KKK Turbo with intake manifold on AFN Quote
The ASZ engine doesn't have a K03 turbocharger; it has a KP-39 or a GT1749VA. It depends, among other things, on whether it's a crosswise or lengthwise installation.
Firstly, you can simply cut out the bracket and have the cut-out piece welded back in place, but upside down. It's going great.
A simpler option would be the GT1749VA without the manifold, which fits perfectly with the AFN engine and exhibits similar performance characteristics to the VB. Only the hose/pipe between the compressor outlet and the pipe leading to the low-pressure coolant needs to be adjusted.
Nothing seems to be working with VB anymore! Neither the support bracket, nor the downpipe, the rear engine mount, the oil return system, the oil supply system, the intercooler, or the intake snorkel are present... however, at this point, the engine is unrecognizable.
For the intake manifold, I simply had a small flange machined.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oily intake manifold Diesel Engine Technology
No new posts Intake Manifold Questions: Details & FAQs Diesel Engine Technology
No new posts Intake Manifold Gasket: Replacement Guide Diesel Engine Technology
No new posts Intake Manifold for 96kW PD Engine Diesel Engine Technology
