Saw Tooth Profile: Causes & Tolerances
ObenbeiMutti
Post21-10-2005, 10:20    Subject: Saw Tooth Profile: Causes & Tolerances Quote
Yesterday, after repeatedly noticing suspiciously loud rolling noises while driving slowly, I inspected my tire and diagnosed it with a saw-tooth profile.
In Abrollrichtung pro Aussenstollen ein Abnutzungsdifferenz zum entspr. Neighbor's tunnel.
possibly 0.5 mm.
Where does it come from? The shock absorbers are probably fine.
Only noticeable damage consists of hard impacts from deck fittings or cross joints.
Could it be related to the alignment or camber?
Or even on the tire itself? That's the original equipment tire.
or is that completely normal?
Is it a multi-link rear axle?
Thank you.
Translated on 14-08-2026, 2:12.
Boro
Post21-10-2005, 10:53    Subject: Saw Tooth Profile: Causes & Tolerances Quote
'I've also experienced saw-toothing on various tire types! But in my case, it seems to be significantly more than 0.5 mm, probably around 1.5 mm, and it's quite noisy. This is likely due to the 225-width tires I have on my Ibiza 6K and the relatively light weight at the rear axle.'
Translated on 14-08-2026, 2:14.
thom
Post24-10-2005, 11:04    Subject: Saw Tooth Profile: Causes & Tolerances Quote
I once had it on an Audi 80 on the front axle. The reason for this was worn-out strut mounts.
Thomas.
Translated on 14-08-2026, 2:15.
Back to top Profile PM Email
Julian
Post24-10-2005, 13:31    Subject: Saw Tooth Profile: Causes & Tolerances Quote
possibly 0.5 mm.
Was the situation with the driven axle the same as with the idler axle?
ObenbeiMutti
Post25-10-2005, 9:56    Subject: Saw Tooth Profile: Causes & Tolerances Quote
Oops, I forgot.
It's the trailing axis.
Translated on 14-08-2026, 2:16.
Julian
Post25-10-2005, 16:47    Subject: Saw Tooth Profile: Causes & Tolerances Quote
Oops, I forgot.
It is the trailing axis.
ObenbeiMutti
Post25-10-2005, 17:27    Subject: Saw Tooth Profile: Causes & Tolerances Quote
This is the coffee consumption that disrupts my brain metabolism icon_smile.gif.
It's only the rear axle where the wheels make a noticeably loud rumbling sound, even at low speeds.
Translated on 14-08-2026, 2:17.
No new posts Sticking Disc Brakes: Causes and Solutions General Tips
No new posts MKB AMF Error Codes: Causes and Effects Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Codes, Causes and Effects for MKB ASZ, AXR, ATD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leerlaufruheregelung auf -2,4mg/H --> Ursachen ? Diesel Engine Technology
No new posts Ursachen für Leistungsstreuungen? Diesel Engine Technology
No new posts ESD Wear: Causes and Prevention Diesel Engine Technology
No new posts Camshaft Damage Causes in V6 2.5 TDI Engines Diesel Engine Technology
