Increase the starting fuel quantity for a 2.5 TDI AAT/96 engine.
saxi
Post17-09-2002, 20:20    Subject: Increase the starting fuel quantity for a 2.5 TDI AAT/96 engine. Quote
Hello!
I have read the article on how to increase the starting fuel injection amount for the TDI... Now, my question is: how exactly does this work with the AAT, and in what numerical steps can the amount be increased? 1, 10, or 100? Which value makes sense?
Please contact Martin.
Michael II
Post18-09-2002, 8:55    Subject: Increase the starting fuel quantity for a 2.5 TDI AAT/96 engine. Translating...
[Translating...]
zuerst Login-Prozedure mit dem Login-Code durchführen (Motor-STG)
Dann über Funktion Anpassung den Wert des Adaptions-Kanals ändern.
Schrittweite ist 1. Die Max - bzw. Min werte sind von STG zu STG unterschiedlich.
Tschüss
Michael II
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts Increase Starting Amount? Diesel Engine Technology
No new posts Increase initial fuel quantity with VAG-COM on A6 V6 TDI Diesel Engine Technology
No new posts Ladedruck erhöhen beim ALH Motor / Brauche dringend Hilf... Diesel Engine Technology
No new posts Increase idle speed with VAG-COM? Diesel Engine Technology
