Crankshaft Screw Problem: Causes & Solutions
Go to page: 1, 2  Next
haehnlein
Post14-02-2003, 13:35    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
"Due to the increasing number of reports in the forum regarding stripped wheel bolts of the new generation 12.9 grade, I have come up with the following idea:"
In the Erwin (siehe Fehlerdatenbank) manual, it states that the threads and collar of the torque wrench screw must be free of oil and grease . icon_exclaim.gif In the old screwdrivers' manuals, it mentions lubricating the threads icon_exclaim.gif. icon_exclaim.gif icon_exclaim.gif Perhaps this explains the causes of the problems with the new 12.9 screws . icon_question.gif It's possible that some workshops don't know that these screws are now apparently used without oil, which could lead to them loosening icon_confused.gif. icon_confused.gif
What do you mean?
Best regards, Christian.
Translated on 13-09-2026, 23:53.
christians
Post14-02-2003, 14:19    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
I don't believe that oil will help to loosen it. That would be achieved with anti-seize compound, graphite, or molybdenum disulfide. Oil will be displaced when the screw is tightened. However, especially when tightening "quickly," it's possible that the screw is tightened too much, which could damage the screw itself or, worse, the threads of the crankshaft.
Gruß Christian
Translated on 13-09-2026, 23:55.
haehnlein
Post27-02-2003, 18:15    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
So, this problem is really bothering me icon_mad.gif icon_mad.gif.
@ Christian:
I don't think that oil can be to blame icon_confused.gif.
I found something about that in this forum.
http://www.motor-talk.de/showthread.php?s=4cf98fad5f68cb43277240808549c10c&forumid=146&threadid=53600&highlight=kurbelwellenrad
Some people there say that a worn-out vibration damper is the cause of the problems with the crankshaft pulley... others only see the problem with the central screw. There must be a reason for these problems icon_question.gif. I can hardly imagine that this screw would simply come loose or break off without external influences icon_wink.gif. But perhaps the whole thing is still too tightly dimensioned, even with a new screw icon_question.gif.
There, another employee from an instant typesetting company writes:
"Approximately 80% of all D/TD/TDI engines, including five-cylinder engines, that we overhaul have this type of damage."
That's quite something, isn't it?!?
By the way, here are two pictures of a broken and a new crankshaft! How can I upload the pictures?
Translated on 13-09-2026, 23:56.
christians
Post28-02-2003, 14:24    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
Oil is certainly not to blame for the general problem.
However: If there is a regulation for tightening the screws, it must be followed COMPLETELY. The torque required when tightening with oil is different from the torque required when tightening "without oil."
Otherwise, either the material will be damaged, or the connection will not hold.
Ultimately, torque is not an end in itself, but rather the simplest method for achieving a desired preload in the connection. Unfortunately, it is quite inaccurate. Where the highest reliability is required, such as in nuclear power plants, other methods are used, such as hydraulic or thermal preloading. In these cases, the screw or nut is only tightened by hand.
The newer method, which involves tightening with 90 Nm of torque and rotating 90 degrees, also aims for precise adherence to the target tension.
I looked at the photo from the link, and there's definitely nothing to do with "Anknallen" in that picture.
One could determine the cause of the screws breaking by examining the fracture surface, if one had a broken screw available.
I suspect two possible causes: 1. The pulley, and consequently the screw beneath it, might be pulled slightly towards the engine due to the tension of the belts, which, when the engine is running, would create a fluctuating load on the screw. This is definitely something the screw cannot withstand due to the stress concentration effect in the thread root.
2. If the friction between the wheel and the shaft becomes too low (especially if the vibration damper is also worn), the disc could move relative to the shaft. This initial movement is likely small, but it will increase as the groove wears out.
This could then lead to a fluctuating torsional stress on the screw.
Both can lead to permanent breakage.
If the screw doesn't break, it will eventually stretch, become loose, and may eventually unscrew completely.
Gruß Christian
Translated on 14-09-2026, 0:00.
haehnlein
Post28-02-2003, 14:52    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
Hi Christian,
That sounds good icon_lol.gif icon_exclaim.gif icon_exclaim.gif. However, I still don't understand the issue with the vibration damper icon_confused.gif. Does it break by loosening the central screw, or can it simply fail on its own??? We've discussed this topic before and haven't found a solution icon_cry.gif.
Now, the question arises whether this screw should be proactively replaced during the timing belt change. I know someone who replaces this screw plus the sprocket every 90,000 km icon_confused.gif icon_confused.gif. There's certainly a risk that the thread is damaged, and then you have a problem icon_evil.gif.
Could one not detect damage early by measuring the oscillation amplitude at the outer edge of the vibration damper (axially to the KW) icon_question.gif? The question is only how one can measure the play with DIY tools icon_confused.gif.
Translated on 14-09-2026, 0:03.
christians
Post28-02-2003, 16:04    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
Unfortunately, I haven't had a broken vibration damper in my hands yet. However, I can imagine that if the rubber is deteriorating, the rotating mass would continue to oscillate, while simultaneously being braked more strongly at the endpoints. This would loosen the normally fixed screw connection in the same way as if you were using an impact wrench for an extended period.
Gruß Christian
Translated on 14-09-2026, 0:04.
Diesel-Dirk
Post31-07-2005, 16:50    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
Hello.
Mich hat's nun auch erwischt! Nach 275 Tkm hat sich die KW-Schraube gelockert. Ich weiß nicht, ob die meine Werkstatt beim ersten ZR-Wechsel die neue 12.9er Schraube rein hat oder ob sie schon von vorherein drin war. Jedenfalls hab ich sie nir angerührt, da ich der Meinung war, neue Schraube und alles fest = alles OK. Seit einiger Zeit hatte ich Probleme beim 'Kaltstart'. Dies schob ich jedoch auf eine nicht ganz korrekte Einstellung der ESP nach dem Reinigen des MSW. An dieser Stelle gleich noch ein großes DANKE an die Anleitung dazu. Nach einem Jahr eindlich wieder Ruckelfrei!! Jedenfalls hab ich die Pumpe nochmal eingestellt und es hatte sich nicht gebessert. Nach dem der Motor auf der Autobahn gestern des öfteren in Notlauf gegangen ist und mir VAG - COM danach einen Einspritzbeginn von 0 im Diagramm angezeigt hat, hab ich den Riementrieb zerlegt. Es sah alles noch gut aus. Jedoch kam mir eine Menge Schwingungsrost entgegen. Die Schraube mußte noch mit etwas Kraft gelöst werden. Also richtig locker war sie noch nicht. Als Ursache des Ganzen vermute ich den Schwinungsdämpfer. Mir ist schon vor einiger Zeit aufgefallen, das dieser recht unrund läuft. Viel ist da aber gar nicht dran, war verschleißen kann. Leider kostet das Teil ca. 250 Euro. D'I could just buy another used engine right away and drive that one until it breaks down!'
Does the crankshaft stub *necessarily* need to be reworked, and is it advisable to use Loctite when installing the crankshaft bolt?
Translated on 14-09-2026, 0:05.
lappen
Post31-07-2005, 17:22    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
My condolences!
I would just plan the strut mount and that would be good enough. The Loctite experiment seems too risky to me! There have already been several cases where it went wrong...
Translated on 14-09-2026, 0:06.
Diesel-Dirk
Post31-07-2005, 21:09    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
How does the timing belt replacement actually work? Can the engine stay in place during the process, and can any VW workshop perform this repair?
m.w.
Post31-07-2005, 22:32    Subject: Refinement: Improving Your Work Quote
VW has this small wooden box (they even lent it to me once so I could make my own).
It consists of a mandrel that is screwed into the thread of the KW (likely a component), and a milling cutter that is guided by the mandrel and constantly rotated in a circular motion.
Gibt herrlich lange Arme und macht besonders im Winter bei Schnee unter nem Bulli fürchterlich viel Spaß. FIt works, but...
You'll need approximately 10cm of space in front of the rear axle; after that, it should fit when installed.
Hi, Marcus.
Translated on 14-09-2026, 0:07.
D. Kurz
Post06-08-2005, 17:51    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
Hello!
The process of smoothing the crankshaft journal icon_cry.gif only works up to a certain point. The problem is that the profile on the shaft wears down, against the direction of rotation. Even if the contact surface is perfectly smooth }, it will only last for a certain amount of time. In my Passat }, it was only 30,000 km.
However, there are companies that specialize in repairing such crankshafts. But, in my opinion, it's something to reconsider if the vehicle has more than 200,000 km on the odometer, as it might be more cost-effective to overhaul the entire engine. This is a tricky cost issue, and it might not be worth it for the specific car in question.
Dominique.
Translated on 14-09-2026, 0:08.
haehnlein
Post06-08-2005, 23:56    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
D. Kurz wrote:
The contact surface can be as flat as it wants... but it will still only last for a certain amount of time. In my Passat, it was only 30,000 km. icon_cry.gif
Hello Dominique,
I always thought that the force between the KW wheel and the KW shaft is only transmitted through the contact surface (not through the screw). Therefore, the profile of the KW stub should be quite irrelevant, as long as the contact surface is flat icon_confused.gif icon_question.gif.
____________
Kein Auto mehr!
Translated on 14-09-2026, 0:10.
goettmann
Post07-08-2005, 15:30    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
The process of smoothing the crankshaft journal only works up to a certain point. The problem is that the profile on the shaft wears down against the direction of rotation. No matter how smooth the contact surface is, it will only last for a certain amount of time. In my Passat, it was only good for about 30,000 kilometers.
What kind of profile?
If you're referring to the notch for the KW wheel, it's not necessary. The notch has no mechanical function whatsoever; it only indicates the orientation for mounting the KW wheel. The forces are transmitted solely through the surface pressure between the KW component and the KW wheel.
If it only lasted 30,000 km for you, I would definitely confront the person who did the work. I've planned several maintenance schedules, and for some of them, the timing belt needs to be replaced again after the incident.
Translated on 14-09-2026, 0:11.
D. Kurz
Post07-08-2005, 16:59    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
@Goettmann
I'm not comfortable doing things that might cause problems for myself... In principle, you're right, but there's still a certain degree of guidance provided by the profile. The missing segment with its corresponding counterpart in the wheel hub probably has a reason. I've had to do this kind of work on several 1Z cars, due to my job, and unfortunately, I've had the painful experience that if there's not enough surface area on the segment to provide sufficient support for fixing the wheel, then a press fit and the contact area won't help, and the wheel will inevitably come loose. This has happened a few times in workshops I know. Of course, it's possible that further loosening of the wheel after repairing the wheel hub could be caused by a worn-out shock absorber, for example, but I can't judge that.
That was just an experience made by myself and by others. Of course, it's possible that my Passat, in the hands of its new owner, is still running 'green' thanks to Bern assembly adhesive, but I don't care about that, thanks to my Golf icon_twisted.gif. As long as there are no signs of a loose rear wheel bearing on the AFN (which supposedly shouldn't happen...), I'll just leave it alone and only change the timing belt regularly.
Dominique.
Translated on 14-09-2026, 0:14.
Diesel-Dirk
Post07-08-2005, 22:22    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
Since my engine already had the M12.9 screw installed, and the timing belt pulley still came loose, I would be cautious with the AFN engine as well. As far as I know, the belt drive system is the same for both engines.
I see the problem in the circumferential bending stress on the screw connection. The pre-tension of the screw can decrease, and the sprocket wheel can easily become loose. The vibration damper then further exacerbates this issue when the shaft rotates.
Translated on 14-09-2026, 0:15.
RazsmithII
Post31-10-2005, 2:18    Subject: Crankshaft Screw Problem: Causes & Solutions Quote
Well, in my opinion, as confirmed by two very knowledgeable people, Loctite is the only solution to prevent the KW screw from coming loose again... I had this problem 15,000 km ago, and now it's the exact same problem again... Poor starting when the engine is cold. icon_arrow.gif This time, I'm using the red Loctite. icon_idea.gif
Translated on 14-09-2026, 0:16.
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
No new posts Crankshaft Screw TDI Diesel Engine Technology
No new posts Kurbelwellenschraube bei TDI 90 PS (ALH) Diesel Engine Technology
No new posts Crankshaft bolt torque specification ALH G4 Diesel Engine Technology
No new posts Crankshaft bolt for TDI engines Diesel Engine Technology
