vagtuning Guest
04-11-2005, 14:10 Subject: A6 2.5 TDI Chip Tuning: Erfahrungen & Forum |
Please let me know briefly, including the engine power, circuit type, and body style.
I'm looking for someone who has an Allroad with a BAU engine, automatic transmission, and a chip tune.
Translated on 03-10-2026, 11:23.
Troubleshooter Guest
06-11-2005, 17:21 Subject: A6 2.5 TDI Chip Tuning: Erfahrungen & Forum |
210 horsepower.
420 Nm.
It runs smoothly. There's not much more that can be recommended for this vehicle.
Matthias.
Translated on 03-10-2026, 11:24.
Thomas Profi-Schrauber
Joined: 04/17/2002 Posts: 329 Karma: +2 / -0 Location: Darmstadt
10-11-2005, 12:52 Subject: A6 2.5 TDI Chip Tuning: Erfahrungen & Forum |
There are several V6 TDI models in my family and among my acquaintances.
These engines all have a VP44 injection pump, which itself has a control unit that limits the amount of fuel injected and the injection timing. As far as I know, the amount is limited to approximately 44 or 45 mg per injection. In other words, the actual power output is likely no higher than 190-195 horsepower. Every tuner claims more, but that's simply not possible.
However, in the early days, some of the first 150hp V6 TDI engines didn't have this limitation. It seems that every engine in the Allroad has this restriction.
I'm wondering how to identify these pumps. Is there a way to bypass this limitation, so the motor can actually perform better, or is it just another case of misleading marketing?
Quote: | | There isn't much more that can be recommended for that vehicle. |
Have you already achieved higher performance? What happened? Why is it no longer recommended?
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 03-10-2026, 11:25.
10-11-2005, 17:32 Subject: A6 2.5 TDI Chip Tuning: Erfahrungen & Forum |
With the Allroad, it seems that every engine has this limitation.
For the Allroad with STG number 4Z7907401A and SW number 354376, there is definitely no speed limiter present, as we have measured some of them on the test bench with 225 horsepower. However, the 2.5 TDI engines should not be considered 'good candidates for tuning.'
Translated on 03-10-2026, 11:27.
vagtuning Guest
10-11-2005, 18:41 Subject: A6 2.5 TDI Chip Tuning: Erfahrungen & Forum |
I would be very worried about the SW number... are you sure about that?
10-11-2005, 18:49 Subject: A6 2.5 TDI Chip Tuning: Erfahrungen & Forum |
I would be very worried about the SW number... are you sure about that??
Yes, why?
Translated on 03-10-2026, 11:28.
vagtuning Guest
10-11-2005, 18:51 Subject: A6 2.5 TDI Chip Tuning: Erfahrungen & Forum |
I can hardly imagine that; in the past 10 years, I haven't encountered a single VAG data point that exceeded the four-digit range!
10-11-2005, 18:56 Subject: A6 2.5 TDI Chip Tuning: Erfahrungen & Forum |
I can hardly imagine that, I haven't experienced any data volume at VAG in the past 10 years that has exceeded the four-digit range!
Uh, sorry.
What is the chip number?
Translated on 03-10-2026, 11:29.
christians Profi-Schrauber
10-11-2005, 20:54 Subject: A6 2.5 TDI Chip Tuning: Erfahrungen & Forum |
I once read somewhere in a document about 25 kW per cylinder, which would be 204 horsepower.
However, the text did not specify how this limit is determined.
Gruß Christian
vagtuning Guest
10-11-2005, 21:01 Subject: A6 2.5 TDI Chip Tuning: Erfahrungen & Forum |
That's precisely the performance that *** specifies after the chip tuning process.
11-11-2005, 10:13 Subject: A6 2.5 TDI Chip Tuning: Erfahrungen & Forum |
Is it possible that the limitations are different?
That means one is limited at 192, another at 204, and yet another at 225?
Are there any experiences available regarding these engines without speed limitations?
@vagtuning
You are right  .
But honestly, subjectively speaking, the car doesn't feel like it has 204 horsepower to me.
(Passat 3B, aftermarket chip) I'd like to have the car tested on a dynamometer sometime and I'm curious to see what the results will be.
@trouble
Quote: | | not to be classified as a "good tuning project". |
How did you come to that conclusion?
Similarly, one can equip this engine with different injectors, a different ATL (or even two  ), etc.
(Assuming the pump is not limited.)
The question then is, which part will fail first.
Unfortunately, for example, having the camshaft reground is four times more expensive and time-consuming than it is for an 8V-TDI engine. This then raises the question of cost-benefit analysis.
Have you had any experience with things like that? Or why isn't the engine a good candidate for tuning?
Thomas.
Translated on 03-10-2026, 11:31.
