LED Headlights: Bright & Powerful
René_S
Post30-11-2005, 22:49    Subject: LED Headlights: Bright & Powerful Quote
Hello fellow enthusiasts,
While looking for more light, I measured the voltage at the lamp plug today. It's reading 11.6 volts. Is that normal, or is it sufficient?
Thank you in advance.
R. Schmidt.
Translated on 14-10-2026, 9:05.
bloesch
Post30-11-2005, 23:18    Subject: LED Headlights: Bright & Powerful Quote
It'll be alright.
christians
Post01-12-2005, 0:01    Subject: LED Headlights: Bright & Powerful Quote
You should probably clean the lenses, but it's difficult to reach them and requires special tools and carefully bent wire.
Gruß Christian
Post01-12-2005, 9:45    Subject: LED Headlights: Bright & Powerful Quote
We once had a similar issue with a 1992 35i. The headlights would get a little dimmer each winter. Unlike you, the voltage was even lower. Because we were lazy and it was a winter car anyway, we installed two relays in each lamp and tapped the power directly from the battery. That made the lights bright again. However, later on, we also experienced other problems, and we discovered that the cable from the alternator to the battery was so corroded that we had to replace it.
Translated on 14-10-2026, 9:06.
leo_b
Avatar-leo_b
Post01-12-2005, 15:19    Subject: Headlight Voltage: Troubleshooting & Solutions Quote
René_S wrote:
Hello fellow mechanics,
R. Schmidt
hi,
How was it measured?
- with or without light source.
- motor on or off (and also speed?)
- What was the actual voltage at the battery terminals at the same time?
The voltage would be okay if:
1. engine off
2. measured with a light source.
best regards, leo
Translated on 14-10-2026, 9:07.
No new posts Golf 4 Headlights: Replacement & Upgrade Diesel Engine Technology
No new posts DEPO Headlights: Buy Online & Save! Diesel Engine Technology
No new posts Golf 4 Headlight Installation Guide Transmission, Chassis, Body & Interior
No new posts Gas Pedal Sensor Voltage Reading Diesel Engine Technology
