Longlife Oil Change: Benefits & How-To
awissus001
Karma: +0 / -1   Thank you, like it!
Post28-11-2005, 8:27    Subject: Longlife Oil Change: Benefits & How-To Quote
"Can anyone explain to me in a clear and understandable way how I can change the service interval on my Bora TDI 110 HP from the standard interval to the 'Longlife' interval? I've already tried searching for information, but unfortunately, I haven't found what I was looking for."
Translated on 14-08-2026, 2:41.
Ross-Tech-Support
Post28-11-2005, 9:01    Subject: Longlife Oil Change: Benefits & How-To Quote
What is the production/model year?
What are the values in adaptation channels 40-44 of the instrument cluster, and what is the current coding of the instrument cluster? The part number might also be relevant.
Translated on 14-08-2026, 2:42.
Post28-11-2005, 12:25    Subject: Longlife Oil Change: Benefits & How-To Quote
Of course, the engine should also support long-life oil; this is not just a software change in the instrument cluster in conjunction with a different type of oil.
Ross-Tech-Support
Post28-11-2005, 12:38    Subject: Longlife Oil Change: Benefits & How-To Quote
Rainer K. wrote:
/viewtopic.php?t=3139
I'm not aware of an adaptation channel 45 existing for the Volkswagen Golf 4.
Translated on 14-08-2026, 2:43.
Post28-11-2005, 21:01    Subject: Longlife Oil Change: Benefits & How-To Quote
Besswerwisser wrote:
I'm not aware of an adaptation channel 45 existing for the Golf 4.
You not, but I:
 File size:  48.64 KB
 Viewed:  4519 times
Translated on 14-08-2026, 2:44.
Post28-11-2005, 21:49    Subject: Longlife Oil Change: Benefits & How-To Translating...
[Translating...]
Ross-Tech-Support
Post29-11-2005, 16:20    Subject: Longlife Oil Change: Benefits & How-To Quote
Bertil wrote:
You don't, but I do :
What is the current coding of your AI?
http://wp1013454.wp025.webpack.hosteurope.de/pics/no_45.png
Post29-11-2005, 17:09    Subject: Longlife Oil Change: Benefits & How-To Quote
Unlike your korrekt! (01112).
Your car is programmed for the US market. There is no "Longlife" oil change interval available there, regardless of what features are retrofitted.
There are actually some combination receivers that no longer have channel 45 (which was eventually changed to MJ04).
No idea why.
The G5 has reconnected with him (1 = fixed interest / 2 = light interest). Don't ask about the meaning.
Translated on 14-08-2026, 2:45.
Ross-Tech-Support
Post29-11-2005, 17:24    Subject: Longlife Oil Change: Benefits & How-To Quote
Bertil wrote:
Unlike your korrekt! (01112),...
Your car is coded for the US market. There is no "LongLife" oil specification there, regardless of what features are retrofitted.
See above, I've updated the Screenshot again; the country code has no influence on the WIV adaptation channels, neither for this AI/vehicle nor for others. icon_rolleyes.gif
Bertil wrote:
The G5 has him again (1 = fixed interest / 2 = low-level interest). Don't ask about the meaning.
Because there are no more coding options available, and the WIV guidelines have finally been implemented correctly. icon_wink.gif
P.S.: But ultimately, none of this solves the original poster's problems... he really needs to post the relevant data so that people can help him.
*edit*
Problem found.
http://wp1013454.wp025.webpack.hosteurope.de/pics/with_45.png
Bertil wrote:
There are actually some combinations that no longer have channel 45 (eventually MJ04).
No idea why.
VDO combination instruments do not have channel 45, while Bosch/Motometer combination instruments do.
Translated on 14-08-2026, 2:48.
awissus001
Post29-11-2005, 20:31    Subject: Longlife Oil Change: Benefits & How-To Quote
You're very welcome.
I have read your posts and will adjust the data of the instrument cluster in the next few days.
Translated on 14-08-2026, 2:50.
Post29-11-2005, 22:18    Subject: Longlife Oil Change: Benefits & How-To Quote
Therefore, we are both right.
I know that. I didn't claim that there isn't a channel 45 in general... icon_smile.gif
@awissus001Viewing profile: awissus001
Instead of searching, check the service booklet for the code "QG1". If it's not listed there, you don't need to look any further because your car doesn't have long-life oil specifications.
Translated on 14-08-2026, 2:51.
awissus001
Post10-12-2005, 15:56    Subject: Longlife Oil Change: Benefits & How-To Quote
Okay, thank you again for your contributions. It helped. I was able to access the service menu and enter all the settings from channel 40 to 45, but I had some problems with the oil quality setting, although it eventually worked.
Translated on 14-08-2026, 2:52.
No new posts VAG Longlife Oil Standards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Longlife Service: Your Best Choice Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ZR Interval: ASV & 120,000 km Diesel Engine Technology
No new posts Timing belt replacement interval for AHF-TDI engines Diesel Engine Technology
No new posts vag-com and service interval indicator Diesel Engine Technology
This topic is locked, you cannot edit or reply. Resetting the service interval on an Audi A3 8P On-Board Diagnostics (OBD)
