Multitronic Problems Audi A6 2.5 TDI
oldewurtel
Post12-12-2005, 19:08    Subject: Multitronic Problems Audi A6 2.5 TDI Quote
Dear fellow enthusiasts,
My acquaintance just told me again about the problems he's having with his A6, manufactured in October 2003, with a 2.5L TDI engine.
It's the third time in two years that his A6 has broken down.
The scenario has always been the same.
He drives normally in the morning and stops at the next (or even the one after next) intersection due to traffic. When releasing the gas pedal or braking, a strange noise can be heard coming from the transmission/engine area. When starting or accelerating, the engine doesn't rev up anymore.
After (repeatedly) turning the ignition on and off, he manages to get it running again.
And now for the kicker: There's no error in the memory!
Even the workshop is at a loss.
Is there a linkage between the Multitronic system (due to the noises) and the MSG (due to the lack of response to the 'throttle' potentiometer) such that a fault in the MT system effectively disables the MSG?
Do you have any ideas?
More detailed data (e.g., ICD codes, GKB codes) will be provided later.
K. Oldewurtel
Translated on 29-09-2026, 4:33.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post12-12-2005, 22:13    Subject: Multitronic Problems Audi A6 2.5 TDI Quote
This can happen when the valve body in the transmission gets dirty and the valves can no longer switch properly. There are already aftermarket valve bodies available for this model, based on the year of manufacture.
If the car is experiencing jerky starts, it could be due to an issue with the clutch adaptation, which might then trigger the control unit to enter a limp mode.
The workshop could extract data from the measurement data blocks.
"Best regards, Farni."
B.Eng (FH) u. KFZ Meister
Translated on 29-09-2026, 4:36.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Multitronic Problems: Troubleshooting & Solutions Transmission, Chassis, Body & Interior
No new posts Audi A5 2.7 TDI Multitronic: Common Problems Transmission, Chassis, Body & Interior
No new posts Multitronic: The Ultimate Guide Diesel Engine Technology
No new posts Multitronic Tiptronic: Explained & Compared On-Board Diagnostics (OBD)
