Touran Gear Ratios: 6-Speed Transmission Data
TDI-NAXTEX
Post18-01-2006, 9:06    Subject: Touran Gear Ratios: 6-Speed Transmission Data Quote
Hello everyone,
Could someone please look up the differential and gear ratios for transmissions GQN and FYG? Unfortunately, these are not yet included in the GKB list.
Has anyone ever tried attaching the casing and gears from the 5th and 6th gear to a standard ASD/CPY transmission, for example? Does it fit without extensive modifications?
Thank you very much.
Translated on 25-07-2026, 23:06.
TDI-NAXTEX
Post20-01-2006, 10:23    Subject: Touran Gear Ratios: 6-Speed Transmission Data Quote
Is anyone actually at the information desk?
Passat 3C Variant mit 2,0 TDI
Translated on 25-07-2026, 23:07.
Mampf
Karma: +8 / -1   Thank you, like it!
Post23-01-2006, 19:46    Subject: Gear Ratios for VW Touran 6-Speed Transmission Quote
TDI-NAXTEX wrote:
Hello everyone,
According to http://www.AKTE.auto2.ru/vw/TOU/2003/409/51/4076607/.
is - if I haven't made a mistake and the information on the page is correct - with GQN and FYG.
Axle translation 62/17, the translation from...
1. Gang 34/9, from...
2. Gang 33/16, from...
3. Gang 32/22, from...
4. Aisle 31/28, from...
5. Aisle 28/32, from...
6th gear, 29/40, and from...
Return process???
Crunch.
Translated on 25-07-2026, 23:08.
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku VW Touran, GRA schaltet ab Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sharan/Alhambra/Galaxy(AFN) 5-Gang. Ändern 5.Gang? Diesel Engine Technology
No new posts Golf 5 1.9 TDI 5-speed 6-speed gearbox ZMS clutch Diesel Engine Technology
No new posts Speed signal at 6th gear is the same as 5th gear? Transmission, Chassis, Body & Interior
No new posts 6 Gang -Getriebe in G4 ALH mit 5 Gang Diesel Engine Technology
