Klausen Blaumann
16-01-2006, 10:31 Subject: Pb LMMs: Key Differences Explained |
There are two different LMM (Mass Air Flow Sensor) models from Pierburg for the T4 TDI.
1. LMS 7.18221.51.0 replaces 7.18221.01.0.
2. LMS 7.18221.58.0 replaces 7.18221.08.0.
I still have the LMM with the old connector (two-row).
My original VW chassis number is 074 906 461.
What is the difference between the two models?
Which one should I order?
Translated on 13-09-2026, 20:57.
16-01-2006, 16:50 Subject: Pb LMMs: Key Differences Explained |
Unfortunately, the image is heavily compressed, but my Periburg exhaust system for a Golf 3 TDI 90 hp (1Z) is the top one on your list, based on the VW part numbers you mentioned.
| Description: |
| File size: |
26.68 KB |
| Viewed: |
3428 times |
Translated on 13-09-2026, 20:59.
Profile PM Garage |
Klausen Blaumann
16-01-2006, 22:07 Subject: Pb LMMs: Key Differences Explained |
Yep, that's him.
Can the 7.18221.08.0 be converted to a ....01.0 model, or can the connectors be rewired?
The ...08.0 costs much less.
