Pb LMMs: Key Differences Explained
Klausen
Post16-01-2006, 10:31    Subject: Pb LMMs: Key Differences Explained Quote
There are two different LMM (Mass Air Flow Sensor) models from Pierburg for the T4 TDI.
1. LMS 7.18221.51.0 replaces 7.18221.01.0.
2. LMS 7.18221.58.0 replaces 7.18221.08.0.
I still have the LMM with the old connector (two-row).
My original VW chassis number is 074 906 461.
What is the difference between the two models?
Which one should I order?
Translated on 13-09-2026, 20:57.
Post16-01-2006, 16:50    Subject: Pb LMMs: Key Differences Explained Quote
Unfortunately, the image is heavily compressed, but my Periburg exhaust system for a Golf 3 TDI 90 hp (1Z) is the top one on your list, based on the VW part numbers you mentioned.
 File size:  26.68 KB
 Viewed:  3428 times
Translated on 13-09-2026, 20:59.
Klausen
Post16-01-2006, 22:07    Subject: Pb LMMs: Key Differences Explained Quote
Yep, that's him.
Can the 7.18221.08.0 be converted to a ....01.0 model, or can the connectors be rewired?
The ...08.0 costs much less.
No new posts Bosch MAF Sensors: Identical or Different? Diesel Engine Technology
No new posts Volkswagen Golf 1.9 TDI 74 - 77 kW Diesel Engine Technology
No new posts V6 TDI: Differences between engine codes AFB and AKN Diesel Engine Technology
No new posts ALH vs. AFN Engine: Differences and Specs Diesel Engine Technology
