TDI 2.5: Compression Problems & Solutions
Au00
Post22-01-2006, 12:44    Subject: TDI 2.5: Compression Problems & Solutions Quote
I'm having the following problem. The compression in my V6 TDI AKN engine is distributed as follows (from cylinder 1 to 6): 27-29-31-31-32-31. When the engine is cold, this causes rough running, and the engine smokes excessively. I noticed the compression loss in mid-November and subsequently removed the cylinder head. The valves for cylinders 1-3 were re-ground, as cylinders 1 and 2 were leaking, and the hydraulic lifters were replaced. After that, the problem was gone, and the full power was restored. icon_smile.gif. The compression was above 30 on all cylinders. Now, I've noticed over the past 4 weeks that the problem is gradually reappearing. Today, I checked the compression again, and I see that cylinder 1 has 28, and cylinder 2 has 29. Can anyone help me understand what else this could be?
"Au00"
Translated on 12-10-2026, 4:01.
Henrik
Post25-01-2006, 15:17    Subject: TDI 2.5: Compression Problems & Solutions Quote
Well, the target compaction value is between 27-33 bar...
Everything is still going well!
Otherwise, it could be the piston rings, the head gasket might be damaged again, or the valves might not be closing completely.
Translated on 12-10-2026, 4:02.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post25-01-2006, 20:55    Subject: TDI 2.5: Compression Problems & Solutions Quote
The compression is actually already in the foundational area.
Take a look at the idle speed control. It often indicates a faulty fuel injector.
If it's defective, it can cause jerking throughout the entire speed range. icon_wink.gif It's also possible to have an uneven idle speed even when the engine is idling. }
B.Eng (FH) u. KFZ Meister
Translated on 12-10-2026, 4:03.
Au00
Post29-01-2006, 23:26    Subject: TDI 2.5: Compression Problems & Solutions Quote
Thank you for the response. I plan to replace the rocker arms for cylinders 1-3 soon, and possibly the camshafts (they already show signs of wear).
Translated on 12-10-2026, 4:04.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Compression: Explained and Optimized Diesel Engine Technology
No new posts AHF: Poor Compression - Causes & Solutions Diesel Engine Technology
No new posts A4 B6 2.5 TDI AKE Air Filter Diesel Engine Technology
No new posts AKE V6 TDI: Low Compression Issues Diesel Engine Technology
