Audi A6 4F Instrument Cluster, VAG-COM.
dakoal
Post01-02-2006, 13:25    Subject: Audi A6 4F Instrument Cluster, VAG-COM. Quote
It's about a 2005 Audi A6 4F Avant 3.0 TDI quattro with full equipment.
The interface is the HEX-CAN-USB from dieselschraubershop.
After my acquaintance's instrument cluster was incorrectly coded, as described HERE, we managed to enter a different coding.
From that point on, we were able to code everything (the reason was to disable the seatbelt warning).
Unfortunately, it is no longer possible to enter a coding value greater than 2000xxx. VAGOM 504 indicates that only values up to 1478xxx can be entered.
According to the table on de.openxxx.org, his A6 would result in a number greater than 3,000,000. Therefore, we need to display the Avant as a sedan in the onboard computer, because we can no longer add the number 1024 to the first four digits of the seven-digit number.
Do I need to use a different version of VAGCOM, or does anyone else have any ideas?
[edit: It didn't work with 512.1 either.]
Thank you for the information.
Sure, here's the translation:
"Best regards," or "Sincerely,".
dakoal
____________________________________
Audi A6 Avant (C4) 2,5TDIi MKB:AEL, BJ 1995 @ 220tkm //www.spritmonitor.de/image_116461_1.png
VW Golf III 1,9D MKB:1Y, BJ 1995 @ 182tkm R.I.P. (Rest in Poland)
Translated on 19-10-2026, 16:13.
Back to top Profile PM Email
Uwe@Ross-Tech
Post02-02-2006, 1:58    Subject: Audi A6 4F Instrument Cluster, VAG-COM. Quote
There should be a file named 'CodingLog.TXT' in the 'DEBUG' subdirectory. Please send it to me.
-Uwe-
[email protected]
Translated on 19-10-2026, 16:16.
dakoal
Post02-02-2006, 10:23    Subject: Audi A6 4F Instrument Cluster, VAG-COM. Quote
All the requested information will be sent via private message and will also be posted here.
I'll receive the files/data today.
dakoal
Translated on 19-10-2026, 16:17.
dakoal
Post02-02-2006, 21:43    Subject: Audi A6 4F Instrument Cluster, VAG-COM. Quote
I have saved the "codinglog.txt" file and a memory dump (including all TCU numbers) on my system.
LINK
Combination instrument is:
Address 17: Combination instrument.
Control unit: 4F0 910 930 A
Komponente: KOMBIINSTR. M73 H16 0630
Encoding: 0047891
Workshop code: WSC 06348.
No errors found.
dakoal
Translated on 19-10-2026, 16:18.
dakoal
Post05-02-2006, 18:00    Subject: SEO: Best Practices for Success Quote
Hello everyone.
Thanks to your great support, the problem has been resolved.
The solution should be written by Sebastian or Uwe; I don't want any unofficial information to be shared here.
Thank you again to the two of you, and great praise for the wonderful work.
dakoal
Translated on 19-10-2026, 16:20.
Post05-02-2006, 18:08    Subject: Audi A6 4F Instrument Cluster, VAG-COM. Quote
Thank you icon_cool.gif. We are, after all, the official Ross-Tech distributor.
Translated on 19-10-2026, 16:21.
Ross-Tech-Support
Post06-02-2006, 1:54    Subject: Audi A6 4F Instrument Cluster, VAG-COM. Quote
The problem is that Audi has decided to slightly extend the coding, meaning a few more bits have been added. VAG-COM version 512.1 cannot yet handle this, but version 512.2 will also be officially available soon.
No new posts Software error in the instrument cluster - workshop action Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Avant 2.5 TDI: Power Loss Troubleshooting Diesel Engine Technology
No new posts Audi 80 Avant Wheel Alignment - Caster Adjustment Transmission, Chassis, Body & Interior
No new posts Audi 80 Avant 1Z: Dynamic Injection Timing Type? Diesel Engine Technology
No new posts Audi 80 Avant TDI: Durable Chip Tuning On-Board Diagnostics (OBD)
