pax wrote: |
If you have already narrowed down the cause, then simply remove the gearbox-side of the driveshaft and play around with the joint a bit. Perhaps, one can already notice a certain peculiarity.
I will check this soon, as I am also planning to replace the clutch anyway.
It's not that the vibrations are very strong, but they are definitely noticeable. Interestingly, they are barely noticeable as long as I own the car (20,000 km), and only become noticeable when there are corresponding centrifugal forces acting on the front axle.
A defective inner joint should also be noticeable when driving straight ahead under load.
Maybe someone among us has already solved this specific problem, especially with the 3B5.
