Audi A4 8E: Standheizung Installation & Reparatur
wuzel80
Post09-02-2006, 3:34    Subject: Audi A4 8E: Standheizung Installation & Reparatur Quote
Is there a way to turn on the auxiliary heater in my A4 8E, manufactured in 04/2003, using my mobile phone?
Building (or buying) a circuit that outputs a +12V or ground signal when a mobile phone receives a call is not a problem, but can I connect it to the auxiliary heater so that it turns on?
I didn't install the original remote control. Does anyone know how it works when you want to turn it on? Does the receiver only transmit a +12V or ground signal, or is there more to it?
Thank you very much in advance!
Translated on 02-09-2026, 23:34.
Post09-02-2006, 9:42    Subject: Audi A4 8E: Standheizung Installation & Reparatur Quote
/viewtopic.php?t=11517&highlight=gsm
/viewtopic.php?t=11577&highlight=handy
Use the search function, and you'll find answers. Otherwise, read the text above first, and perhaps your questions will be answered.
Translated on 02-09-2026, 23:35.
wolfi_b
Post09-02-2006, 11:22    Subject: Audi A4 8E: Standheizung Installation & Probleme Quote
wuzel80 wrote:
Building (or buying) a circuit that outputs a +12V or ground signal when a mobile phone call is received is not a problem, but can I connect it to the auxiliary heater so that it turns on?
Aftermarket auxiliary heaters are activated with +12V. As long as 12V is present, the heater will run; a single pulse is not sufficient. However, this may not be the case for auxiliary heaters installed from the factory, as they may operate via bus systems instead.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 02-09-2026, 23:36.
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Standheizung Einbau: D5WSC mit Easystart R+ Installation Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Audi A4 Auxiliary Heater / Parking Heater Diesel Engine Technology
No new posts Audi 2.7 TDI Radiator Fan Control with Auxiliary Heater Diesel Engine Technology
No new posts Auxiliary Heater Audi Q7 Compatibility Diesel Engine Technology
No new posts Audi A4: Park Heater Installation (2007) On-Board Diagnostics (OBD)
