Data Bus Software Status Monitoring: Error 18263
olkoo
Post20-02-2006, 19:28    Subject: Data Bus Software Status Monitoring: Error 18263 Quote
Hello.
I had an error code entry in the MSG (Modular Service Gateway) today.
18263 Data Bus Software Status Monitoring.
P1855-35-00
I can't find this error message in the manual.
Can someone tell me more about it?
Passat 3BG 2003, engine code AVF EYF (1.9 PD, 96 kW, TT5).
Sure, no problem. Here's the translation:
"Thank you in advance."
Olli.
Translated on 27-08-2026, 7:02.
Post20-02-2006, 20:16    Subject: Data Bus Software Status Monitoring: Error 18263 Quote
Too bad...
18263 Data bus drive software status monitoring (data bus drive)
I would say that a control unit on the data bus, specifically related to the drivetrain, detected that another unit was not running the correct (original) software version.
I'll see if I can find anything.
Translated on 27-08-2026, 7:03.
Ross-Tech-Support
Post20-02-2006, 21:06    Subject: Data Bus Software Status Monitoring: Error 18263 Quote
Okay, this is about incorrect software versions or faulty control units that are installed in the CAN drive system. If you can ensure that the control units and software versions are correct, then the error can be ignored.
Translated on 27-08-2026, 7:04.
olkoo
Post20-02-2006, 21:17    Subject: Data Bus Software Status Monitoring: Error 18263 Quote
Thank you in advance for the answers.
olli
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fehler 18262 P1854 Datenbus Antrieb Hardware defekt On-Board Diagnostics (OBD)
No new posts Oil Pressure Monitoring for PD Engines Diesel Engine Technology
No new posts Audi A8 Trailer Hitch Coding - Data Bus Error On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Data Bus Error 01336: Single-Wire Solution On-Board Diagnostics (OBD)
