Airbag Warning: Seat Adjustment Issues
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Kuhni
Post06-03-2006, 5:44    Subject: Airbag Warning: Seat Adjustment Issues Quote
Hello everyone,
After moving the passenger seat all the way forward to transport a large roll of carpet...
after pushing it back and uprighting the backrest, when you turn it on,
The ignition in the MFA (Multi-Function Display) shows an airbag warning with a beep. Additionally, the warning light is not working.
find out more.
I found the side airbag connector under the seat (on the seat side, yellow).
The connector was checked (visually inspected and tested for loose connections), and nothing unusual was found.
Bleibt dieser Fehler permanent im Speicher oder löscht der sich von selber. I suspect a...
'Instability' or 'wobbling' after adjusting the seat.
The vehicle is a 2000 Golf ALH, and the seats have manual height adjustment.
Is there any risk involved, or can the vehicle be driven for a few days until the problem is diagnosed?
Can they be used again? (Except that the airbags might not deploy.)
I live here in the southwestern United States, and everyone drives slowly. icon_wink.gif
Regards...
....Kuhni!
Translated on 27-09-2026, 16:19.
Kuhni
Post06-03-2006, 6:06    Subject: Airbag Warning: Seat Adjustment Issues Quote
Here's: /viewtopic.php?t=10958&highlight=airbag
I've found everything I need to know to get started.
No offense, but from my perspective, this thread can be flushed down the toilet and serve as a 'negative example.'
Regards...
...Kuhni!
Translated on 27-09-2026, 16:21.
Kuhni
Post07-03-2006, 7:19    Subject: Airbag Warning: Seat Adjustment Issues Quote
Hello everyone,
Is the thread still active? Okay, then here's the solution:
Control unit read, the following log was retrieved:
'Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein.'
Address 15: Airbags.
Control unit: 6Q0 909 605 A
Part number: 0F AIRBAG VW5 01 0004
Encoding: 12358
Workshop code: WSC 31414.
'One error found:'
01217 - Driver's side front airbag igniter (N199)
32-10 - Resistance value too high - Intermittent.
Then I wiggled the plug, and the problem disappeared.
Regards...
... Kuhni!
Translated on 27-09-2026, 16:23.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Warning about the "Friendly" ones Diesel Engine Technology
No new posts Relay Clicking After Start / Cold Start Problem Diesel Engine Technology
No new posts Audi 100 2.5 TDI, engine code ABP, issues after chip tuning Diesel Engine Technology
No new posts 2.0 TDI CR (CAGA): Cold Start Issues & Fixes Diesel Engine Technology
