| Lowering with VCDS: Electronic Ride Height Calibration | |
| dieselschrauber |
The following instructions explain how to calibrate the "zero position" of the suspension control unit and adjust the vehicle height using VCDS. This applies to the VW Phaeton (Type 3D), VW Touareg (Type 7L), Audi A6 (Type 4F), Audi A8 (Type 4E), Audi Allroad (Type 4B), and Audi Q7 (Type 4L).
Necessary equipment:
The factory settings for the vehicles are...
Audi A6 (4F) sport suspension: xxx mm (front) and xxx mm (rear). Feedback welcome. Audi A8 (4E) standard suspension: 416 mm (front) and 398 mm (rear). Audi A8 (4E) sport suspension: 396 mm (front) and 378 mm (rear). Audi Q7 (4L) standard suspension: 465 mm (front) and 449 mm (rear). Audi Allroad (4B) standard suspension: xxx mm (front) and xxx mm (rear). Feedback welcome. VW Phaeton (for markets outside Europe): 407 mm (front) and 401 mm (rear). VW Phaeton North American version: 417 mm (front) and 411 mm (rear). VW Touareg (7L) standard suspension height: 497 mm (front) and 502 mm (rear). VW Touareg (7L) Off-road ground clearance: 488 mm (front) and 498 mm (rear). Procedure:
Jetzt ist die Fahrwerkshöhe kalibriert. Gibt man statt der gemessenen Werte z.B. 15mm größere Werte an, wird sich die Fahrposition des Autos 15mm tiefer einstellen. Für For smaller values, the opposite is true.
Translated on 21-08-2026, 18:47. |
| Ratings - Lowering with VCDS: Electronic Ride Height Calibration | |
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 2 - View ratings |
Foren- und Portal-Software: V8.0 © 2003 - 2026 Kaufmann Automotive GmbH & Shop für Kfz-Diagnosegeräte. Parse time: 0.032s
