G3 Door Lock Freezing: Strange Issue?
Go to page: 1, 2, 3  Next
Post09-11-2004, 10:56    Subject: G3 Door Lock Freezing: Strange Issue? Quote
Hi.
After filling my garage with junk, my Golf 3 has to sleep outside.
"For the past two mornings, I've been experiencing some strange behavior with the passenger-side door."
- Opened the gate using the remote control.
- The BFT gate did not unlock (probably because the button inside was frozen).
- With a little patience and some force, the button popped up.
- but the door still wouldn't open.
- ZV to - ZV on
- Now the door opens as well.
What is freezing?
Why have the students at the university been having such a hard time opening the doors lately, even when behaving normally (they've been struggling with the external handle, and they've been very reluctant to open them)?
Has anyone ever experienced this kind of behavior at the castle before?
Any information - besides "replace the lock"?
Thank you.
Translated on 05-09-2026, 18:04.
Georg-TDI
Post09-11-2004, 11:46    Subject: G3 Door Lock Freezing: Strange Issue? Quote
I had the same problem last winter.
At sub-zero temperatures (just below freezing), the door lock on the passenger side did not open immediately.
After pressing the central locking button via radio signal, only three doors opened, and the passenger door button was still down. Only after locking and unlocking again did the right door unlock. It wasn't a coincidence; it was a pattern. That's the only way I could get the right door to open.
That's why I suspect that something was frozen and could only thaw when it was reopened. The cause must be located in the lock mechanism.
At much lower temperatures (-15 to -5), this phenomenon was no longer observed. It is likely due to 'dry frost,' where larger ice crystals in the lock resulted in poorer adhesion.
I didn't repair or replace anything because I always managed to open the door using a specific method.
Starting this year, hopefully this problem will no longer occur, as my Golf will spend the winter in a heated underground garage. icon_lol.gif
Has anyone else encountered this problem?
Best regards, Georg.
Translated on 05-09-2026, 18:07.
Post10-11-2004, 8:26    Subject: G3 Door Lock Freezing: Strange Issue? Quote
I'm also experiencing the same issue. One morning, the driver's door also showed the same problem. After that, I was planning to have it checked, but then it got significantly colder, and the error was no longer detectable...
Conclusion: Same problem, no solution.
Translated on 05-09-2026, 18:09.
Rudi
Post10-11-2004, 9:34    Subject: G3 Door Lock Freezing: Strange Issue? Quote
I had the same problem (driver's side).
Funny side effect: the car locked itself again...
The drama ended with a 'click,' indicating (mechanical activation).
with the key) the interior of the castle opened icon_evil.gif.
At VW, I was informed that the lock cylinder and eccentric are now...
would have been designed to be significantly more stable.
Parts required per page:
Eccentric 1H0 837 223 B.
Lock cylinder 1H0 837 061 G or 1H0 837 061 H (depending on the system).
Part number 1H0 837 237 D.
Cost: approximately 13 EUR per page.
Although the fundamental mechanical structure hasn't changed,
My lock hasn't refrozen since then (it's been about three years).
Best regards, Rudi.
Translated on 05-09-2026, 18:10.
Post10-11-2004, 10:00    Subject: G3 Door Lock Freezing: Strange Issue? Quote
"Cylinder lock"
I don't have any more! I only have one left, the one on the tailgate (as an entry point).
So, they can't freeze solid icon_wink.gif.
"Nevertheless, thank you for the numbers."
Could it be that the SAFE-LOCK, or whatever it's called, freezes? These are powerful electromagnets that hold the buttons at the bottom in place. If the contact surfaces (magnet to iron) are wet, the SAFE-LOCK can freeze, which means it unlocks more easily than intended.
Translated on 05-09-2026, 18:13.
wutz
Karma: +11 / -1   Thank you, like it!
2006 Seat Leon
Post10-11-2004, 10:10    Subject: G3 Door Lock Freezing: Strange Issue? Quote
I had a very similar problem with my girlfriend's Polo. The cause was moisture in the lock (not the door lock). After removing it, drying it out, and applying new lubricant, the problem disappeared. It was quite a complicated job, but it was worth it.
DocSnydor
Post10-11-2004, 10:50    Subject: G3 Door Lock Freezing: Strange Issue? Quote
@martin
'The 'Safelock' is actually activated by the pump, right? Your central locking system on the Golf is the same as on the 35i, which is pneumatic...'
Translated on 05-09-2026, 18:14.
Post10-11-2004, 13:04    Subject: G3 Door Lock Freezing: Strange Issue? Quote
Okay, I have the pneumatic power steering.
But I thought the pump had magnets that would engage immediately because it was too slow, and then the pump would start up.
If you try to pull the levers, they are held very tightly in place, WITHOUT the pump starting.
Translated on 05-09-2026, 18:15.
wolfi_b
Post10-11-2004, 13:06    Subject: G3 Door Lock Freezing: Strange Issue? Quote
DocSnydor wrote:
Isn't the "Safelock" function actually controlled by the pump?
Your central locking system on the Golf is the same as on the 35i, namely pneumatic...
dieselmartin wrote:
Yes, I think so too. At least, in my case, it seems to be caused by the pneumatic cylinder.
"Schliesszylinder" ????
I don't have any more! I only have one left, the one on the tailgate (as an entry point) icon_biggrin.gif.
Did you not clear it away, though? }
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 05-09-2026, 18:16.
Post10-11-2004, 13:19    Subject: G3 Door Lock Freezing: Strange Issue? Quote
wolfi_b wrote:
I have two rear grab handles installed in the front.
Because the door lock cylinders were already damaged (the locking plates were missing, and the slot was already full of debris), and since I have central locking with a folding key fob...
Translated on 05-09-2026, 18:17.
Post10-11-2004, 13:37    Subject: G3 Door Lock Freezing: Strange Issue? Quote
dieselmartin wrote:
Because the door lock cylinders were already damaged (the locking plates were missing, and the slot could easily fill up with debris), and since I have central locking with a folding key fob...
And what do you do when the car doesn't cooperate, even if it's just because the battery is dead?
Breaking into your own car, or nailing the doors shut... icon_eek.gif icon_question.gif
Translated on 05-09-2026, 18:18.
wolfi_b
Post10-11-2004, 13:56    Subject: G3 Door Lock Freezing: Strange Issue? Quote
@ulfViewing profile: ulf
dieselmartin wrote:
I only have one left, the one on the tailgate (as a door handle).
1993 Audi 80 B4 1Z
Post10-11-2004, 14:51    Subject: G3 Door Lock Freezing: Strange Issue? Quote
wolfi_b wrote:
@ulf
Translated on 05-09-2026, 18:19.
Post10-11-2004, 15:25    Subject: G3 Door Lock Freezing: Strange Issue? Quote
Since my van has to serve as a camper, I'm planning to install an interior handle on the rear door sometime before next summer, so I can get *out* of it, not just *in*.
Do those SAFE-LOCK magnets that I described actually exist, or not?
On the other hand, I probably have to remove the lock anyway, so I can search for them myself icon_confused.gif.
DocSnydor
Post10-11-2004, 15:44    Subject: G3 Door Lock Freezing: Strange Issue? Quote
I did the same thing on my car. Apparently, you can easily unlock VWs with a 'Polish key,' but that immediately deactivates the central locking system. However, I left the tailgate lock enabled as a backup.
Translated on 05-09-2026, 18:20.
WarLord
Post10-11-2004, 20:18    Subject: G3 Door Lock Freezing: Strange Issue? Quote
Simply put: For cars with a dead battery, an additional power connection is installed (in a discreet location) to provide external power.
Otherwise, the central locking system on models like the Golf III/Passat 35i etc. doesn't typically have any issues with the same pneumatic system.
Best regards, WarLord.
Translated on 05-09-2026, 18:21.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
