Headlights Vento/Golf III: Common Problems
[email protected]
Karma: +1 / -1   Thank you, like it!
Post30-03-2006, 18:13    Subject: Headlights Vento/Golf III: Common Problems Quote
Hello everyone,
Unfortunately, I had a mishap today while changing the headlight bulb. When I pushed the housing back into the reflector, the reflector detached from the plastic rod of the headlight leveling system. I haven't been able to reattach the rod to the reflector, despite trying various methods. Perhaps someone has experience with the headlights of a Golf III or Vento and can offer advice on how to reattach the rod to the reflector.
Do I need to remove the headlight assembly for this? Or the motor of the headlight leveling system? I would be very grateful for any advice, as I am a student, and a repair from a specialized workshop would likely be very time-consuming.
Thank you very much!
Translated on 04-09-2026, 16:44.
Post31-03-2006, 14:20    Subject: Headlights Vento/Golf III: Common Problems Quote
I can't tell you if you can manage without removing it, as I had already removed it back then (I upgraded to a dual-SW system).
Expanding it is definitely not a problem. The grill is just clipped on, so you need to use a flathead screwdriver to push all the clips out. Then you can simply pull it off.
The headlight is secured with four screws (size 8 or 10) and can then be easily removed.
Expandable for experienced users in under 10 minutes.
Guste.
Translated on 04-09-2026, 16:46.
No new posts XENON...2 Bulbs, 2 Days, One Headlight General Tips
No new posts Passat 3B Headlight Vibration: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary about foggy headlights and odors inside Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Speedometer for VW Vento Diesel Engine Technology
No new posts Golf 4 Headlights: Alternatives & Replacements Transmission, Chassis, Body & Interior
No new posts Golf 4 Xenon Headlights, Generation 2 Transmission, Chassis, Body & Interior
No new posts Vento Center Console: Parts & Accessories Transmission, Chassis, Body & Interior
