VW & Mercedes Diagnostic Kit: Which One to Buy?
doktor44
Karma: +0 / -3   Thank you, like it!
Post21-04-2006, 23:46    Subject: VW & Mercedes Diagnostic Kit: Which One to Buy? Quote
Hello!
I own a VW T3 with a 1z TDI engine (from a 1994 Passat) and a Mercedes E 220 CDI from 2002.
Both engines are now equipped with a large number of electronic components, which are prone to causing many errors.
Is there a diagnostic kit that covers both models? (Especially in terms of software?!)
I've already browsed the shop a bit, but I've only found vague information about compatibility with Mercedes models.
Can anyone give me a tip?
I wanted to spend a maximum of 500 euros for the entire package!
Thorben.
Translated on 13-10-2026, 7:30.
Post22-04-2006, 8:41    Subject: VW & Mercedes Diagnostic Kit: Which One to Buy? Quote
Hello Torben,
"The 1Z issue can be addressed using VAG-COM and one of the semi-professional diagnostic systems. For Mercedes vehicles, there's a chance it can be resolved via OBD2 using the ISO protocol, which at least allows access to the engine control unit."
Other solutions for the Benz are in a completely different price range; you could easily add a zero to the price.
Specifically for Mercedes and BMW, we offer the following:
https://shop.dieselschrauber.org/en/obd-diagnosegeraet-p-363.php
We offer, across various manufacturers, OBD2 solutions via CAN.
https://shop.dieselschrauber.org/en/obd2-diagnose-kit-p-321.php
Translated on 13-10-2026, 7:32.
Ross-Tech-Support
Post22-04-2006, 9:58    Subject: VW & Mercedes Diagnostic Kit: Which One to Buy? Quote
A single zero probably won't be enough, but it also depends on what you specifically want to do with it. For example, the coverage of functions offered by most third-party providers is never identical or similar to that of the original device (MB Stardiagnosis). Usually, all-around devices like Gutmann or Bosch are sufficient for most everyday workshop tasks, but as I said, there's a limit, and eventually, only the original device can go further. As for VAG-COM, I would consider it a commendable exception, because in terms of functionality, it comes close to an original device and is certainly not suitable for comparisons with other brands.
Translated on 13-10-2026, 7:33.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts VCDS: On-board diagnostics for VAG vehicles Troubleshooting & Guides
No new posts Mercedes G290TD Diagnosis: OM602.983 (W461) On-Board Diagnostics (OBD)
No new posts ??? Which TDI should I choose? Diesel Engine Technology
No new posts Turbo Replacement: Which Turbo to Choose? Diesel Engine Technology
No new posts Exhaust manifold AEL. Can we use the 2-part one from 10V? Diesel Engine Technology
