Rim Width for VW Golf 4: What Fits?
Hubse
Post29-04-2002, 13:36    Subject: Rim Width for VW Golf 4: What Fits? Quote
Hello.
I want to install 8' x 17 inch wheels with 225/45 17 tires on my Golf IV. The approval documents (ABE) often state: 'If necessary, ensure sufficient clearance by modifying the body.' So, do the 8' x 17 inch wheels fit a Golf without any modifications, and is it possible to also use wheel spacers (to increase the track width)?
Thank you.
Hubse.
Translated on 05-09-2026, 13:32.
Michael748
Post01-05-2002, 13:13    Subject: Rim Width for VW Golf 4: What Fits? Quote
Hello Hubse,
It always depends on the bead depth of the rim.
You'll likely be able to handle ET 40, but ET 0 will probably be more difficult.
Translated on 05-09-2026, 13:33.
Mr.X
Post02-05-2002, 15:28    Subject: Rim Width for VW Golf 4: What Fits? Quote
Hi.
Okay, normally you should be able to fit 8x17 ET 25-30 wheels with 225 tires on the front and 10x17 ET 20 wheels with 245 tires on the rear without any problems.
Stefan
Translated on 05-09-2026, 13:34.
No new posts Calix Motor Heater Installation Guide Troubleshooting & Guides
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Welche Kupplung paßt? Diesel Engine Technology
No new posts Install VW Golf 3 TDI 1.9L Engine Diesel Engine Technology
No new posts TDI Timing Belt Tensioner: AEL (A6/C4) - Doesn't Fit! Diesel Engine Technology
No new posts AJM Engine Repair: Tips for VW Golf 4 Diesel Engine Technology
