TDI Injectors: Meaning & Function (AVF)
WVG
Post29-04-2006, 10:05    Subject: TDI Injectors: Meaning & Function (AVF) Quote
Hello!
Does anyone know the meaning of the measurement data blocks in the climate control unit?
What is the translation of "meines 1.9 TDI AVF (Audi A6 Bj.11/2001)?"
best regards
wvg
Translated on 27-09-2026, 18:02.
Post29-04-2006, 11:28    Subject: TDI Injectors: Meaning & Function (AVF) Quote
Please always include the VAG part number in such cases; it greatly simplifies the work.
WVG
Post29-04-2006, 13:10    Subject: TDI Injectors: Meaning & Function (AVF) Quote
Hi!
Here is the VAG number.
4B0 820 043 AC
Component: A6 Climate Control System.
Soft Coding: 00103
best regards
wvg
Translated on 27-09-2026, 18:03.
Post29-04-2006, 13:41    Subject: TDI Injectors: Meaning & Function (AVF) Quote
Save the file.
http://www.ross-tech.com/vag-com/download/label-files/4A0-820-043.lbl or
http://download.openobd.org/labelfiles/german/8L0-820-043-1D.lbl or
http://download.openobd.org/labelfiles/german/8L0-820-043-2D.lbl
under the name '4B0-820-043-AC.lbl' in your VAG-COM label directory.
Feedback regarding the plausibility of the measurement value labels is desired icon_smile.gif.
Does this device have one or two displays?
Sebastian can probably tell you more about that.
Translated on 27-09-2026, 18:04.
WVG
Post29-04-2006, 14:17    Subject: TDI Injectors: Meaning & Function (AVF) Quote
Hi!
Thank you!
The control panel has a temperature display for both the left and right sides.
In the middle, the blower speed setting is displayed again.
best regards
wvg
Can you perhaps help me solve my problem?
My issue is described under "General Technology" (see WVG).
Translated on 27-09-2026, 18:05.
WVG
Post29-04-2006, 15:30    Subject: TDI Injectors: Meaning & Function (AVF) Quote
Hi!
Hier ein Feedback bzgl. der Plausibilität der Label^s. Unfortunately.
Do you perhaps have a few more of those?
...wvg
Translated on 27-09-2026, 18:06.
Ross-Tech-Support
Post30-04-2006, 1:15    Subject: TDI Injectors: Meaning & Function (AVF) Quote
Rainer K. wrote:
Feedback regarding the plausibility of the measurement value labels is welcome icon_smile.gif
Neither 4A0-820-043.lbl, nor 8L0-820-043-1D.lbl, nor 8L0-820-043-2D.lbl fit even remotely to this questionable control unit. Perhaps next time, instead of making random guesses, simply refer to the relevant guides, as this is more likely to yield a correct result.
They also can't, because none of the control units for which files were mentioned have any connection to the one installed in your car. A control unit from an A4 (8E) would be similar up to manufacturing date 006, but after that, the values are shifted by -1, so it's not a real solution either.
WVG wrote:
...do you perhaps have a few other pairs in your quiver?
You don't necessarily need "a few" other options; it's enough to have the right one, or to be able to recognize what works and what doesn't. This depends on which VAG-COM version you are using, so it would be helpful if you could provide the version number. If you are using a current version 512.x, there is a solution for your problem. However, if you are using an older version (e.g., 409.1, which was the version as of September 2004), you need to be careful, as these represent an older development stage and are no longer supported, especially regarding the "documentation." Even if data (e.g., label files) from newer versions can be made to work with them (e.g., by renaming), there is no guarantee of the accuracy or completeness of the displayed data.
Translated on 27-09-2026, 18:09.
WVG
Post30-04-2006, 9:28    Subject: TDI Injectors: Meaning & Function (AVF) Quote
Hello!
Thank you for the explanations icon_idea.gif.
I'll probably have to get a newer version eventually.
Currently, my problem with the label files has been resolved.
Yesterday, I noticed that my compressor is stuck.
wvg
Translated on 27-09-2026, 18:11.
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Alarm Source Meaning A8 4E On-Board Diagnostics (OBD)
No new posts MWB 3/AGR: Meaning of Duty Cycle Ratio On-Board Diagnostics (OBD)
No new posts Track Constant Meaning: Explained & Defined Transmission, Chassis, Body & Interior
No new posts Meaning of the Air Mass Standard Value? On-Board Diagnostics (OBD)
